Post new topic Reply to topic  [ 9 posts ]
 Post subject: SLR shaving?
PostPosted: Tue Jul 13, 2004 3:16 am
any one ever shave down an SLR? i know superlite shaved down an old flite he had, i contemplated that, but it was either the red flite (which feels good) black flite (feels like ass, not broken in) Red slr (good) or black SLR (good)
so i pulled the cover off the red SLR. removed the padding, and busted out the dremel to the tail end to split the shell more. i'll post up pictures later, btw starting weight was 134. will have finished weight tomorrow
 Post subject: Re: SLR shaving?
PostPosted: Tue Jul 13, 2004 5:22 am
Yeah I did, weight down to 111.9 grams
Starting weight was 147 grams with the cover on.
jeremyb
PlusOneLap.com: Everything Cyclocross
 Post subject:
PostPosted: Tue Jul 13, 2004 6:18 am
Jeremy, I think your weight savings would have been more thorough, if you took the weight from the rear of the saddle, rather than comprimising comfort (if so).
 Post subject:
PostPosted: Tue Jul 13, 2004 7:32 am
comfort and SLR in the same sentence? You are funny. :D :D :P
 Post subject:
PostPosted: Tue Jul 13, 2004 8:29 am
I used to ride a Flite some years ago, then changed to SLR, which is more comfy. I once stripped an worn-out SLR, but after 2 days I bought a new one, because it's too un-comfy for me. I'll try to make it more comfy by drilling some holes in it.
 Post subject:
PostPosted: Tue Jul 13, 2004 8:54 am
Try this shortcut from the MTB section:
Knut got his SLR down to 105g with a dremel.
http://weightweenies.starbike.com/forum ... hlight=slr
Not sure but I think there was another post in the MTB section on a detailed walkthrough of trimming down your old SLR to around 100g
 Post subject:
PostPosted: Tue Jul 13, 2004 4:20 pm
Yep, a dremel is all it takes... :D
http://www.korczak.dk/files/mtb/slr/
I'm not done though - will have to drill it and sand it down to save even more weight. Not for comfort mind you - it's pretty comfy even for 120+km roadrides on 1" slicks @100 PSI...
 Post subject:
PostPosted: Tue Jul 13, 2004 5:43 pm
mine is down to 90g. shaved on the outside and drilled some holes - 4 bigger ones in the middle and 3 on the left and right. they vary from 20mm to 9mm getting smaller towards the front, right and left side...
as my ass doesn't like the hard pure plastic feeling, i started to re-pad it with 2 layers of 3mm foam; 2 stripes, one on the left and one on the right whereas the second layer covers the whole saddle. as the white leather is still in ok condition, i'll re-use it (not to mention the look...)
saddle w/out leather and padding: 90g
new padding: 6g
leather: ~12-15g (not sure about this. it's not cut to fit the new shape yet. right now it's still 19g)
i guess, i'll end up at <110g which isn't superlight but quite ok for a padded and covered slr
*edit* anybody wanting to buy me a digicam? :D
 Post subject:
PostPosted: Tue Jul 13, 2004 5:55 pm
i've been thinking about putting the leather cover back on just to make it look normal so i wont get razzed at work
Users browsing this forum: Google [Bot], Google Adsense [Bot], Majestic-12 [Bot] and 50 guests
This topic is locked, you cannot edit posts or make further replies. Shaving material off heavy rim of Shimano WH-R500 wheel
[ Go to page: 1 ... 7, 8, 9 ]
kai-ming
121
5775
Sat Aug 11, 2012 8:54 am
Tinea Pedis View the latest post
It is currently Sun May 26, 2013 9:41 am
