Post new topic Reply to topic  [ 9 posts ]
 Post subject: The future of Shifting
PostPosted: Thu Jul 08, 2004 1:30 pm
how much longer will rear and front der. be in use, till its replaced by something more efficient, that shifts better under even under the most extreme conditions, how about instant engagement?
what do you guys think will be the next move in cycling. i think Rohloff is a good example - it has a few kinks to be worked out needs to be lightened up, but from all the reviews i have read, and the people i know who have the hub, they say the system is bomb proof. but i am not talking about the hub, there is a modified version that goes in the center of the frame; thus taking the weight off the rear hub and putting it in the center of the bike.
check it out
could this system work for road cycling? i think even now with the extra weight of the Rohloff hub, we can still come in at UCI weight of 15 -15.5 lbs.
here is a pic of a bike that uses the system, it is not a road bike, but just so you get the picture.
What does everyone think, any :idea: does anyone think this could work for a road bike? more info for anyone intrested :arrow: http://www.g-boxx.org/
 Post subject:
PostPosted: Thu Jul 08, 2004 5:30 pm
I know at least three semi pro downhill riders who use that system. Stable weight, less loose bits to break, fast accelerating wheels.
weight vs range of gears and reliability at a light weight would be deciding factors as is cost
It would be good to see some one come up with a new solution. Get Shimano and Campy to get their act together.
 Post subject: Re: Future of Shifting
PostPosted: Fri Jul 09, 2004 1:42 am
Nah. I have seen the Rohloff. It is a giant pig. Even with all of the other components off of an MTB it weighs a tonne. I think we will see the electric Record way before something more revolutionary...
 Post subject:
PostPosted: Fri Jul 09, 2004 5:26 am
I had a Rohloff hub for a bit... on a town bike (closer to a road bike than a mtn bike).
My opinion is that no internal hub (Rohloff included) will be useable (on the road) until the ratios are more suited for the application.
Rohloff's ratios are very evenly spaced, but that's not what's required for road riding. As the gear ratio gets "longer", the ratios need to get closer and closer together. The jumps between the top few gears need to be very, very small.
Until someone addresses this, an internal hub (regardless of weight) will never be a practical alternative to what we have now.
 Post subject:
PostPosted: Fri Jul 09, 2004 11:01 am
its an even 13.6 % jump or something close to that.
thats a good point that you need less of a jump as you go through the gears on the road.
 Post subject:
PostPosted: Fri Jul 09, 2004 8:19 pm
i really hope campy bypasses this electronic shifting and get with G-BOXX or make their own standard. this would be a nice step foward, not baby step to just better der. shifting.
PostPosted: Fri Jul 09, 2004 8:58 pm
I hear you. The problem is that, given the inefficiency of the engine (i.e., us!), there is little to gain from greatly increased mechanical efficiency versus lighter weight (hence this forum), assuming that the system maintains adequate reliability.
The claims that G Boxxers make about mechanical failure of derailleur-based systems belies the fact that it is pneumatic tires that are the leading cause of mechanical failure in road racing and that the rate of failure of modern race components (Dura-Ace, Record) is probably adequate, given the advantage in weight saving.
Additionally, the derailleur-based system IS Campagnolo's own standard. :wink:
 Post subject:
PostPosted: Sat Jul 10, 2004 6:35 am
It's very, VERY difficult to beat a chain for mechanical efficiency. Even having just one or two gear meshes will result in poor efficiency compared to a chain.
IMO, the next step (granted, an evolution, not a revolution) is to get the indexing for the rear derailler *AT* the rear derailler... instead of 5' away at the shifter. That *might* require 2 cables instead of one, but I believe they could be very small. Once the detents are at the derailler, adjustments will be a thing of the past.
Once again; my opinion only...
 Post subject: Zap
PostPosted: Sat Jul 10, 2004 12:41 pm
Shimano has had a go at this, atleast once, and the Mavic Zap system worked this way as well.
Success is how far you you bounce back up after being knocked down
Users browsing this forum: Bing [Bot], Google [Bot], Google Adsense [Bot], HammerTime2, MarkThailand, thecounty and 42 guests
There are no new unread posts for this topic. Road Bikes Disk Brakes/Carbon Wheels Dominant Future?
bluhorizan
10
1500
Tue Aug 21, 2012 1:04 am
kulivontot View the latest post
There are no new unread posts for this topic. O Symmetric with Di2 Shifting
KWalker
Fri Feb 08, 2013 12:09 am
Geoff View the latest post
There are no new unread posts for this topic. Recon cassette shifting
mrfish
Wed Sep 12, 2012 8:59 am
mrfish View the latest post
There are no new unread posts for this topic. Sram Red Front Der. shifting issue?
G6612
Fri Apr 12, 2013 5:28 pm
Hoodsanddrops View the latest post
There are no new unread posts for this topic. Campy 11 Rear Shifting Problem
goldmine848
11
626
Fri Sep 21, 2012 2:43 pm
edmundo View the latest post
It is currently Sat May 25, 2013 7:57 pm
