Post new topic Reply to topic  [ 3 posts ]
Would you buy this?
Yes 44%  44%  [ 8 ]
No 56%  56%  [ 10 ]
Total votes : 18
PostPosted: Wed Jul 07, 2004 5:20 am
A few days ago I received an email from Campagnolo stating that they were to bring out a Carbon crankset.
"For 2005 the Centaur groupset presents an optional carbon-fiber crankset. The Centaur Carbon crankset was designed by applying the same constructive technology as for the Record Carbon and Chorus Carbon series. This involves a careful union of two technologies, namely Multidirectional Carbon Fiber and Unidirectional Carbon Fiber technologies.
In this solution the Multidirectional Carbon Fiber is first spread, creating the component’s overall strength, after which the Unidirectional Carbon Fiber is applied, following the same direction as the stress lines, i.e. all the points where the component is subjected to maximum stress. In this way a component of unbelievable mechanical strength is obtained.
When comparing the results with the same model in aluminium, the differences are extraordinary:
Greater lightness
Greater resistance to static loads
Greater fatigue strength
Greater torsional strength "
My questions are:
-What is the weight?
-What month is it going to be available?
Does anyone here have an 'inside line' and might know the answer to these questions?
 Post subject:
PostPosted: Wed Jul 07, 2004 5:52 am
Well, the only difference between '04 Record and Chorus is 5 chainring bolts, a decal, and about $200!
I suspect this is Chorus just dropped down to the Centaur group.
Don't know actual weight; I suspect availability will be after Interbike, etc.
"Gimondi è un eroe umano, che viene sconfitto ma che continua la sua corsa fino a tornare a vincere." - Enrico Ruggeri
 Post subject:
PostPosted: Wed Jul 07, 2004 6:32 am
My 2004' Carbon Record cranks were 545g 175mm+53/39 rings.
Look that in picture in compact crank. I will get alloy compact Centaur cranks to my cross bike (48/34 rings)
Samu @ www.signature.fi
Users browsing this forum: Google Adsense [Bot] and 58 guests
There are no new unread posts for this topic. Campagnolo chainring won't fit Campag crankset
idler
Sun Apr 07, 2013 5:50 am
idler View the latest post
There are no new unread posts for this topic. Best value carbon crankset for 68mm threaded BB?
Porschenut
10
882
Fri Jun 15, 2012 1:33 am
Porschenut View the latest post
There are no new unread posts for this topic. Force or Centaur?
alexh
31
883
Tue Apr 23, 2013 11:38 pm
alexh View the latest post
There are no new unread posts for this topic. Campy Veloce vs. Centaur
SolidSnake03
39
2092
Wed Feb 06, 2013 2:07 pm
Miller View the latest post
There are no new unread posts for this topic. Campagnolo Pro-fit vs Look Keo
Roel W
7
519
Thu Mar 07, 2013 4:37 pm
Pantani View the latest post
It is currently Fri May 24, 2013 2:25 am
Campagnolo Centaur 10s cassette
