Post new topic Reply to topic  [ 9 posts ]
 Post subject: derailleur pulleys???
PostPosted: Sun Jul 04, 2004 2:32 am
Does anyone out there use these pulleys? Or do you guys know of something better? :?:
 Post subject:
PostPosted: Sun Jul 04, 2004 4:23 am
jcrage wrote:
...Or do you guys know of something better? :?:
Yes, the Tiso pulleys are of very high quality - Also very well priced. The are one of the lightest "known to man".
http://www.tisobike.com
 Post subject:
PostPosted: Sun Jul 04, 2004 5:21 am
Whats the savings?
MAMA SAID KNOCK YOU OUT! HUH!
 Post subject:
PostPosted: Sun Jul 04, 2004 5:46 am
i think they actually add weight. In addition to that, I've never personally seen better der. performance from those pulleys. Stock pulleys are designed to have a certain amount of "float" to properly shift. Those have sealed bearings, no float, no performance.
 Post subject:
PostPosted: Sun Jul 04, 2004 9:17 am
Aren't those alloy pulleys very noisy?
Whow! That's a pretty damn nice garage door!
 Post subject:
PostPosted: Sun Jul 04, 2004 5:05 pm
I am using the Tiso pulleys. They are a little noisier than the standard ones and they actually shift better when everything is adjusted correctly. But if the cable tension is off they are a little worse without the play in the upper pulley.
The best thing is the sealed bearings are smoother than the bushings used in regular pulleys and stay that way much longer.
 Post subject:
PostPosted: Sun Jul 04, 2004 5:19 pm
I am also using Tiso Pulleys, but with Ceramic hybrid bearings. There is a lot to gain there, especially if you are using Campa.
 Post subject:
PostPosted: Mon Jul 05, 2004 5:15 pm
standard campag ones are plastic aren't they??? hard to dee how aluminium ones could be lighter.
Dooz
Dance you cares away, worries for another day, dance your cares away, down at fragglerock.
 Post subject:
PostPosted: Tue Jul 06, 2004 7:24 pm
they could also be carmichael pulleys here in the states. great for the road but fill with crud on MTB's (from experience) great bearing for wet conditions.
Don't know of they are still being made. I have a couple of sets for spares
Users browsing this forum: BeeSeeBee, Bing [Bot], bomber, Exabot [Bot], Google [Bot], mnmasotto and 30 guests
There are no new unread posts for this topic. Fabian Cancellara's Shimano Dura-Ace rear derailleur pulleys
Garret C
15
3342
Fri Jul 06, 2012 10:51 am
Micky B View the latest post
There are no new unread posts for this topic. Low resistance gear pulleys that last..
svrasmussen
10
1119
Tue May 07, 2013 10:08 am
sugarkane View the latest post
There are no new unread posts for this topic. fibre lyte pulleys, where can I find in US?
kevosinn
Wed Aug 29, 2012 1:56 am
kevosinn View the latest post
There are no new unread posts for this topic. Noisy Sram Force Pulleys!!
Mrtomh99
Thu Mar 28, 2013 7:54 pm
Mrtomh99 View the latest post
There are no new unread posts for this topic. Experience with Token Jockey Pulleys?
mellowJohnny
14
1092
Sun Aug 19, 2012 7:53 pm
chazzawoods View the latest post
It is currently Sun May 26, 2013 7:09 am
