Post new topic Reply to topic  [ 5 posts ]
PostPosted: Thu Jul 01, 2004 2:08 am
Hey there, i purchased a Cannondale Slice SI all carbon fork off of Ebay. And i received it today---went to take out the top cap and realized that there appears to be a star nut in there. And i cant get it out. Also, the inside of the steerer tube has deep grooves down the inside of the steerer tube where it looks like the star nut was hammered or pressed into place.
I have always thought that you dont use a star nut in a carbon steerer tube and that you use an expanding wedge as came with my Look HSC4.
Any ideas? or information
jeremyb
PlusOneLap.com: Everything Cyclocross
 Post subject:
PostPosted: Thu Jul 01, 2004 2:13 am
The canondale SI all carbon for ia actually made for use with a star nut, but it has a special top cap that goes into the steerer tube about 30mm.
Did you get the top cap with it? If you didn't you need to aquire one before installing the fork, otherwise you risk crushing the steerer tube.
MAMA SAID KNOCK YOU OUT! HUH!
 Post subject:
PostPosted: Thu Jul 01, 2004 4:22 am
okay good, thanks for the news. Yeah i got the special deep topcap. btw is this setup lighter, or just different? I guess im asking why is it like this?
jeremyb
 Post subject:
PostPosted: Thu Jul 01, 2004 4:58 am
the setup weighs only 14g, so yeah, it's quite a bit lighter then most compression caps, usually 30-40g.
 Post subject:
PostPosted: Thu Jul 01, 2004 5:34 am
Yeah, it's supposed to be in there. You can find the specific docs in the tech section of the Cannondale site. It's a light system but also a bit of a hassle. When you want to remove your stem the top cap doesn't slide off easily. You have to tap the stem with a rubber mallet from the bottom in order to get it out.
Users browsing this forum: Bing [Bot], Exabot [Bot], Goldman, Google Adsense [Bot] and 41 guests
There are no new unread posts for this topic. Cannondale slice top cap for use with star nuts
digiadaamore
Sun Aug 12, 2012 2:06 am
digiadaamore View the latest post
There are no new unread posts for this topic. Cannondale Slice Di2 Project
turas
Thu May 31, 2012 8:44 pm
turas View the latest post
There are no new unread posts for this topic. 2013 Cannondale Slice RS - Available as Frame Module Only?
415brian
Mon Aug 06, 2012 5:32 am
secteurpave View the latest post
There are no new unread posts for this topic. Cervelo Funda, whats the size of star nut
digitalnorbs
Wed Oct 10, 2012 4:24 pm
digitalnorbs View the latest post
There are no new unread posts for this topic. DT Swiss Hub - 36 Step Star Rachet Upgrade
audiophilitis
Mon Feb 11, 2013 2:52 am
audiophilitis View the latest post
It is currently Sun May 26, 2013 9:21 am
