Post new topic Reply to topic  [ 158 posts ]
Go to page Previous  1 ... 7, 8, 9, 10, 11
PostPosted: Fri Jan 25, 2013 2:10 am
Rotor 3d+ SRM is indeed similar to any modern wireless SRM with 2x LTC7PN batteries.
PostPosted: Fri Jan 25, 2013 6:19 pm
So does your significant other know that you are using their cutting board to perform maintenance on your SRM? :mrgreen:
PostPosted: Fri Jan 25, 2013 8:35 pm
WeightySteve wrote:
The only thing keeping the cover on once the rings are removed is friction between the internal rubber seal and the spider housing
however, there is enough friction involved so as not to let the cover "pop off" when you remove the rings. Don't worry, changing the rings is just as trivial as changing them on a normal (non SRM) spider.
Thanks Steve.
PostPosted: Sat Jan 26, 2013 8:07 am
devinci wrote:
DartanianX wrote:
Does anyone know how to use the new software function to check the levels of the battery crank?
I was told its when you dld a training file from the PC7, I guess its via the SRMwin software, but not sure. This is an awesome feature though.
^^ this is it. you must use SRMwin -- this does not work in SRMmac.
not sure if your SRM's firmware had to be updated to make use of this. i know i had a unit that was a newer one (1700h battery life) that displayed the older capacity. i was told it was due to a firmware issue.
PostPosted: Tue Feb 12, 2013 7:02 pm
Is anyone familiar if there is another type of battery which can be used instead of the Keeper LTC-7PN-S4? I'm having a hell of a time finding one in Canada and the ones i find in the US won't ship to Canada.
Or does anyone know of a Canadian source?
Thanks
PostPosted: Tue Feb 12, 2013 8:38 pm
check locally for equivalents under different part numbers like er651625
also try variations with different pin configurations - both bent (s2) and straight-pin (s4) versions are fine, the four-pin version can be used simply by 'peeling' the extra cathode pins away from the case
otherwise, i believe sbc will ship to canada (their 'worldcart' lists it as an option)...
http://www.smallbattery.company.org.uk/
http://www.smallbattery.company.org.uk/ ... ldcart.htm
PostPosted: Wed Feb 13, 2013 2:29 am
Thank you sungod! i think i was being a bit too specific in my search....this makes things much easier.
btw. If anyone in Canada is looking for a replacement battery there is a brand called MadgeTech LTC-7PN. They use them in data loggers, and that sort of thing.
PostPosted: Thu Mar 07, 2013 9:00 pm
Hi, can anyone tell me if this battery suits for the PC V ?!
http://www.reichelt.de/Memopuffer/3GP-6 ... tnr=3GP-60
thnx :)
Post new topic Reply to topic  [ 158 posts ]  Go to page Previous  1 ... 7, 8, 9, 10, 11
Users browsing this forum: Google Adsense [Bot] and 75 guests
There are no new unread posts for this topic. Is it possible to put the EPS battery in a seatpost?
williamsf1
36
2899
Thu May 09, 2013 5:37 pm
g_doraz View the latest post
There are no new unread posts for this topic. Internal battery for Di2 ultegra DIY
Kingston
Wed Feb 13, 2013 5:28 pm
Cyklus View the latest post
There are no new unread posts for this topic. Small Di2 Battery suggestion?
lemond853
Thu Jun 07, 2012 9:29 pm
lemond853 View the latest post
There are no new unread posts for this topic. di2 internal battery connector
daryl1
12
913
Thu Jun 07, 2012 3:07 pm
drmutley View the latest post
There are no new unread posts for this topic. New Calfee intergrated EPS battery stem..
simonanks69
33
2332
Wed Sep 26, 2012 3:11 pm
1spd View the latest post
It is currently Mon May 20, 2013 3:25 pm
