Post new topic Reply to topic  [ 4 posts ]
PostPosted: Sun Jun 27, 2004 2:44 pm
I'd appreciate a quick response as I've been offered a front Zipp 404 wheel (16 spoke) that has a bust spoke and I've to make a quick decision.
Is a spoke replacement as per a normal wheel assuming no other issues arise ?
The current 404s seem to have full carbon rim but this set is a couple of years old and seem to have an ali braking surface - any problems inherant with that age of 404s ?
I recently wrecked my handbuilt front wheel that I use for TTs (and occasionally road races as it's fairly light) and I'm wondering if the 404 might be a suitable replacement. I don't want to buy a pair of wheels unless I have to so a front-only at a good price is ideal for me.
Thanks
 Post subject:
PostPosted: Sun Jun 27, 2004 8:04 pm
Replacing spokes on most wheels should never be a problem. In particular, your wheels, unless the Rim has some deformity then It will be fine.
When you put that spoke in, be sure to use a tension-meter, in order to check that the stress is distributed correctly.
I have a friend who did exactly the same thing, and he fixed it with no problem. :D
 Post subject:
PostPosted: Mon Jun 28, 2004 1:52 pm
Tubular 404s have carbon braking surfaces, clincher versions have alu.
I bought a pair of 404 clinchers a few weeks ago, put them on my bike, realised how terrible the hubs were and took them straight back to my LBS who very graciously exchanged them.
The front hub's carbon cover fell off and the rear wheel was so flexible I couldn't see how anyone was expected to climb or sprint on it. Maybe I got a bad pair, but wouldn't recommend them on the basis of this experience. Corimas are probably better VFM.
rico
 Post subject:
PostPosted: Tue Jun 29, 2004 6:05 pm
Thanks - I'd found a zipp 404 on ebay at what looked a good price but it closed higher than my limit but maybe a 404 isn't what i need anyway going by the comments.
Users browsing this forum: addictR1, bigkraig, Bing [Bot], dalex, deek, Google [Bot], rmerka, sanrensho, TrekUk and 91 guests
There are no new unread posts for this topic. Zipp 404 spoke nipple protruding
ketsana
Fri Mar 08, 2013 6:37 am
clarkson View the latest post
There are no new unread posts for this topic. Novatec wheel bearing replacement
dieselgeezer
11
859
Tue Jan 29, 2013 9:50 pm
kavitator View the latest post
There are no new unread posts for this topic. Replacing a Zipp 88 Spoke Retention ring
BeeSeeBee
Sun Dec 09, 2012 5:01 am
BeeSeeBee View the latest post
There are no new unread posts for this topic. Crash Replacement costs for wheel manufacturers
mxdclt
12
726
Sat Aug 25, 2012 5:22 am
speedwobbles View the latest post
There are no new unread posts for this topic. Attachment(s) HELP:My Lightweight Wheel got a hole on one spoke
lyq0322
Tue Aug 21, 2012 2:19 pm
CarbonSportsGmbH View the latest post
It is currently Tue May 21, 2013 10:01 pm
