Post new topic Reply to topic  [ 19 posts ]
Go to page 1, 2  Next
PostPosted: Tue Jun 22, 2004 8:31 am
What is the ultimate aluminium frame; Principia, Cannondale, Teschner, Pegoretti, DeRosa, Pinerello, Storck?
How do we decide- metals in the alloy, weight, stiffness, longevity, finish, geometry,cost!?
Various magazines and reviewers have given their opinions and no doubt egineers have run tests, but what is the top frame?
I have it on good authority that the Storck EVO is up there, apparently the presidents of Cannondale and Principia own Storcks and they are the inspiration for their frames, and that there a re rebadged Storcks aplenty in the grand tours! Discuss
 Post subject:
PostPosted: Tue Jun 22, 2004 9:26 am
It's a very hard question...
IMO Pinarello makes very good alu frames (on the heavish side...), De Rosa are very good too (they're lighter than Pinarellos). One of less talked about manufactures is Carrera: check their bikes out, cause they're light, well made and they have years of pro-riders experience. All of theese manufacturers build bikes with Dedacciai tubing (although Pinarello uses very custom ones).
The history of rebadging is old as TDF... I wouldn't say a bike is a rebadged one until I've got proofs (e.g. Rebellin's Wilier / Scott, or Armstong 90s Trek/Litespeed).
Bye, Benz.
 Post subject:
PostPosted: Tue Jun 22, 2004 1:33 pm
Do you consider scandium an aluminum alloy?
 Post subject:
PostPosted: Tue Jun 22, 2004 3:12 pm
Yes. Pure Sc would be prohibitively expensive and far too weak.
 Post subject:
PostPosted: Tue Jun 22, 2004 4:06 pm
Here is one that has yet to be mentioned anywhere on this forum.
http://www.ellsworthbikes.com/bikes/flight/index.cfm
 Post subject:
PostPosted: Tue Jun 22, 2004 4:20 pm
The Pros I know who raced on Pinarellos didn't really care for them. They were also heavier than any of them expected.
Personally, I think the question would need to be clarified: is it the ultimate aluminum bike for 1 season or for 5?
 Post subject:
PostPosted: Tue Jun 22, 2004 4:28 pm
A couple to throw in the mix
the litespeed alloy frames are nice, light and responsive. But they do have some hideous colors.
Titus - drop-u frame is a great frame as well
Principia probably for me
 Post subject:
PostPosted: Tue Jun 22, 2004 4:44 pm
Quote:
You know a pure metal isn't an alloy.
Also, no one would ever want to make a pure scandium frame. Scandium is a grain refiner for aluminum the strengthens it's bonds. It is alloyed with aluminum in small quantities ( somewhere around 3%) to make scandium alloy (it's really an aluminum alloy seeing how it is over 90% aluminum, but the guys in marketing thought calling it a "scandium frame" sounds more impressive.)
MAMA SAID KNOCK YOU OUT! HUH!
 Post subject:
PostPosted: Tue Jun 22, 2004 5:21 pm
Thanks Superlite. That's what I meant. Scemantics, Shemantics.
Does the list include them or not!
I Think it should.
 Post subject:
PostPosted: Tue Jun 22, 2004 5:39 pm
I would think that the Scott C-1 is the lightest Scandium frame around at 950 grams and U2 frames as light as 860 grams for Agresti. There is a Denti Solo frame that is U2 tubing and on Murabikes site, is tuned down to 789 grams. :shock: I don't know what size the frame is, it does look extremely small. I don't think it even has clearcoat on it. :?
 Post subject:
PostPosted: Wed Jun 23, 2004 6:34 pm
BMC is extremely good. A pro that lives near me said it is a lot better than Pinarello!!!
PostPosted: Thu Jun 24, 2004 12:04 am
(Pegoretti builds Al too? i thought they excel in steel)
Sounds like the question for a thesis :-)
A racing bike should be as light as possible without sacrificing stiffness or durability. If it looks nice, too, all the better
How much stiffness you need is debatable. I personally like them as stiff as possible.
I notice you forgot Klein in your list. I think the earlier Kleins (when the company was still independent) were the first frames that made the most out of Aluminium.
Examples from the early nineties (Quantum Pro and Quantum II) are still competitive in Weight and especially Stiffness/weight. Outstanding build quality and excellent paintjobs, too! I rate them as the best Al frames there are beause of their overall quality.
Cannondale, Principia and Storck as Klein copies are on the same level and may well have topped the original. Unfortunately Cannondale has taken a kneefall to fashion and uses Al/Carbon mixture now, which in my opinion toes not benefit a frame.
Partly for the same reason I don't care much for italian Al frames.
And the welds of the first Al. Bianchis, Pinarellos and de Rosas were simply awful.
I like the very pretty De Rosa Merak, but they are rumoured to break easily.
Geometry: difficult issue. I think no major brand builds frame geometries that are just plain bad. There are agile frames, and there are well balanced ones - i think it is futile to discuss which one is better. Testride some and get the one which suits you best.
I own two Principias which are bombproof on highspeed descents but have to be forced into tight turns, they feel like a truck compared to the Scott Team Issue which is almost nervous - "italian" geometry :-) . I prefer the Scott.
Modern Sc Frames like the Scott Team Issue '03 or other superlight frames (you mentioned Teschner) can be built lighter, but they have to prove they can last - time will tell.
If you value durability over lightness, stay away from U2 tubing. Teschner for example reduces warranty from 10 years for his Sc frames to 2 years for U2 frames. And Sc frames are possibly not built to last forever, too.
Martin
PS: And as superlite said, a "Scandium" frame contains as much Scandium as an Aluminium frame contains Copper, Titan and Silizium. So every Al frame could be called "Copper" with the same right :)
Snowman and Strong Walker
Scott Sc
my old stuff
my new stuff
 Post subject:
PostPosted: Thu Jun 24, 2004 5:02 pm
It's the one you most like to ride.
Ride lightly!
 Post subject:
PostPosted: Thu Jun 24, 2004 5:28 pm
Fondriest don racer is a nice one. Italian geometry, very light and quality build. Kind of pricey though.
 Post subject:
PostPosted: Fri Jun 25, 2004 12:59 am
Who builds them? How about the carbon Fondriest frames (Top)?
Cheers,
:lol:
"Ride lots." -- Eddy Merckx
Click Here to see my Scott CR1.
Post new topic Reply to topic  [ 19 posts ]  Go to page 1, 2  Next
Users browsing this forum: Google Adsense [Bot], mvacolnago, nigel379, shimmeD and 48 guests
There are no new unread posts for this topic. Cannondale SS EVO Ulimate frameset; Availabikity?
bluhorizan
Wed Jul 18, 2012 5:14 am
timzcat View the latest post
There are no new unread posts for this topic. 30mm 18h aluminium rim
Rob81
Sun Feb 17, 2013 9:21 pm
GonaSovereign View the latest post
There are no new unread posts for this topic. 33 mm 20 h aluminium rim on the market ?
LouisN
Fri Feb 15, 2013 9:44 pm
bm0p700f View the latest post
There are no new unread posts for this topic. Polishing an aluminium stem
GASer
12
813
Sun Nov 11, 2012 11:26 am
User Name View the latest post
There are no new unread posts for this topic. aluminum or aluminium bike thread???
tigoose
Tue Aug 14, 2012 4:58 am
tigoose View the latest post
It is currently Tue Jun 18, 2013 7:32 am
