Post new topic Reply to topic  [ 10 posts ]
 Post subject: Seat shim
PostPosted: Thu Jun 10, 2004 3:02 pm
Need a nice light seat shim 27.2/31.8
any suggestions. I won an Easton ec90 seatpost and want to use it
Also carbon frame, carbon seatpost, any issues with shims between them
 Post subject:
PostPosted: Thu Jun 10, 2004 3:07 pm
USE do a light shim in many sizes and the are made from plastic therefore they are corrosion resistant.............
good luck
Staggerlee
 Post subject:
PostPosted: Thu Jun 10, 2004 3:13 pm
Administrator
I think that is better than an alloy one. I had one in my Al. frame, and it simply corroded to it. Although i greased it it was a b*tch to get out! using pliers and a hammer i finally managed to do it!
Pick the plastic shim
Follow me on twitter. I try to be interesting ;)
On Facebook!
 Post subject:
PostPosted: Thu Jun 10, 2004 3:15 pm
I have 27.2/30.0 USE shim in my hand. It weights 14g...I you happen to want to know it.
Samu @ www.signature.fi
 Post subject: Re: Seat shim
PostPosted: Thu Jun 10, 2004 3:27 pm
This is for your CR1, right?
If so I think you need a 31.6mm post/shim.
I would use the USE acetal shim. Don't use an aluminum one.
Ride lightly!
 Post subject:
PostPosted: Thu Jun 10, 2004 3:55 pm
ÚSE's aluminium ones are for small diameter change shims. They are not made in 31.6/27.2mm size. I use plastiqueones in all my titanium frames.
 Post subject:
PostPosted: Fri Jun 11, 2004 1:14 am
Just finished looking for shims myself. Here are some good sites for the 27.2 to 31.6/31.8 conversion:
http://www.mtbstore.com/find.php?PHPSESSID=b9f06992bcacb179914bb7001d39681e&search_word=seatpost+shim&cat=&zip=&discount=&affiliate_id=
http://www.chainreactioncycles.com/categories.asp?category=Seatposts+Shims&x=5&y=9
http://www.pricepoint.com/detail/12902-275_USESA1-3-Parts-68-Seatposts/Use-Alien-Shim-For-Carbon-Seatpost.htm
http://www.pricepoint.com/detail/11704-275_ROCSH1-3-Parts-68-Seatposts/Rock-Shox-Seatpost-Shim.htm
http://www.excelsports.com/new.asp?page=8&major=2&minor=19&description=SX+Seatpost+Shim&vendorCode=USE
As mentioned, the thermoplastic shims look good for avoiding problems with metal frames (cold welding) and carbon frames (corrosion).
 Post subject:
PostPosted: Tue Jun 15, 2004 1:26 am
Thanks for the info. Actually I will need two shims one for the Scott and for a Titus MTB (31.8)
 Post subject: Scott/shims
PostPosted: Tue Jun 15, 2004 7:01 am
Wouldn't go for shims at all. There is enought choise in 31.6 to make a good choice. The new carbon deda (xl4 ??) in 30 cm. with setback is 160 gramms uncut and can be tuned to 145 gramms with a titanium bold. If you need a longer post the new 2004 campa record isn't a bad choice (I use it in my Scott) uncut 195 gramms.
 Post subject: Re: Scott/shims
PostPosted: Tue Jun 15, 2004 10:51 am
Deda's weight ar far from the actual weight. I would rather go for Tune or Extralite
Users browsing this forum: carbon337, Google [Bot], Google Adsense [Bot], KLabs, rbrtwyn, rgamble, Willier, Yahoo [Bot] and 66 guests
There are no new unread posts for this topic. Shim for a stem, sensible?
TimF
Fri Jun 15, 2012 8:49 am
wassertreter View the latest post
There are no new unread posts for this topic. Chamfered spacer/race/shim for Look integrated headsets
dxs
Wed Oct 10, 2012 10:55 am
dxs View the latest post
There are no new unread posts for this topic. Evo seat collar
quaman26
16
742
Sat Jun 09, 2012 6:50 am
quaman26 View the latest post
There are no new unread posts for this topic. LOOK 695 max seat height
DartanianX
Tue Dec 11, 2012 9:19 pm
OrPe View the latest post
There are no new unread posts for this topic. Attachment(s) Seat Tuning 101
1spd
11
1759
Wed Jan 16, 2013 1:06 am
odin99 View the latest post
It is currently Fri May 24, 2013 8:26 pm
