It is currently Sun Feb 19, 2017 12:56 pm
Post new topic  Reply to topic  [ 12 posts ]
PostPosted: Sun Jun 06, 2004 6:14 pm
I crashed in a race this morning. It was a violent crash, mid-sprint, only about 100m from the finish, involving eight or nine riders. My first thought when I sat up in the middle of the road was 'jeez I hope my bike's OK.'
The Lightweights remain perfectly true and there is not a scratch on them apart from a very slight section of the rim where the CF has delaminated slightly. This could not be said of some of the other wheels involved....
rico
 Post subject:
PostPosted: Sun Jun 06, 2004 6:27 pm
So what´s the best price you have found in the Eu for a set of lightweights? I´ve noticed carbonsports are starting an online direct sale but no prices yet. Around 2000 Euros no?
PostPosted: Sun Jun 06, 2004 6:49 pm
So you're gonna have to buy new wheels anyway :cry:
Damn...
Whow! That's a pretty damn nice garage door!
PostPosted: Sun Jun 06, 2004 8:28 pm
Damn...
Of course a specialist will have to have a look at them, but even carbon fibre parts can be repaired (ask any boat builder), if the damage's not structural.
Martin
Snowman and Strong Walker
Scott Sc
my old stuff
my new stuff
 Post subject:
PostPosted: Mon Jun 07, 2004 1:37 am
I don't think so - it looks cosmetic and it's certainly not structural. Either the LBS who sold me them will deal with it or (if the worst comes to it) I can get them sent back to the factory for a rebake.
PS Martin - what sort of spoke magnet is that on your LWs. Is it one of the Sigma ones that slides on?
rico
 Post subject:
PostPosted: Mon Jun 07, 2004 1:47 am
I can't imagine any part of a lightweight wheel is not structural. If there is a nonstructural part, remove it and have lighterweight wheels. Also, you can not see underlying damage in composite structures. If it was a structural aircraft part it would be C scanned to find the hidden damage and then repaired or removed from service. In my opinion you should be very conservative when your health is at risk. Maybe you can get the wheels replaced for a nominal amount.
 Post subject: Quick Check
PostPosted: Mon Jun 07, 2004 2:17 am
The quick and dirty check for delamonation:
1. Find a coin/spanner/screwdriver with a nice ring when tapped.
2. Hold area of composite part to be tested horizontal (this wont be to hard with a wheel, but frames are more difficult).
3. From a hight of approx 10mm (It is more important to keep the hight consistant then finding an exact hight) drop coin/object on surface.
4. It should ring on the good and thud on the delamonated parts.
5. As a rough check tap about every 30-50mm and when you hear thuding close the tap spacing to mark out the exact area of delamination.
Boeing uses a more expensive version of this technique to test their wings and flaps (theirs involves water jets and ultrasonic taps in the water stream).
Success is how far you you bounce back up after being knocked down
 Post subject:
PostPosted: Mon Jun 07, 2004 5:58 am
rico
Yes its the sigma, i had wrapped around a strap of scotch tape to secure it. But it is off the wheel now, i'm going to replace it with a Tune.
Martin
Scott Sc
my old stuff
my new stuff
 Post subject: Lightweight
PostPosted: Mon Jun 07, 2004 9:07 am
How strange this may sound: most carbon parts should be exchanged after a (severe) crash.
Stem, fork and front wheel are the first thing you have to think of.
I had my Leightweight frontwheel crashed last year and the wheel looked perfectly fine afterwards, X rays however showed several internal cracks so ordering a new one was the only safe (read expensive) solution. Leightweights should be treated as any other cheaper carbon wheel and I guess this is the risk of racing (if you can't afford replacing just don't buy them). The other solution is to sell the parts after a crash through e-bay as I seen done by others several times.
 Post subject: Re: Lightweight
PostPosted: Mon Jun 07, 2004 9:40 am
:shock: :lol:
 Post subject: Re: Quick Check
PostPosted: Mon Jun 07, 2004 11:39 am
I've heard of the technique before. I have a CF seat post that has a clearly visible indentation in a small section where it has been clamped by a frame for a year. It rings the same as any other part of the post and there no thud whatsoever. Does this mean the damage isn't structural? BTW, I'm not currently using the seat post anymore.
 Post subject: Deformation
PostPosted: Mon Jun 07, 2004 1:08 pm
A part can undergo plastic defomation (creep) in a loaded situation.
With the slow onset of the deformation both metal and composite parts can oftern survive this. In some ways composite parts can survive the seat post clamp deformation better. The metal post can be more affected by the stress riser, and the reinforcing fibers in the composite post can redirect the load.
This topic is locked, you cannot edit posts or make further replies. ENVE SES 4.5 or Lightweight???
jerrybrabus
32
3370
Fri Jul 29, 2016 5:02 am
reggiebaseball View the latest post
There are no new unread posts for this topic. Lightweight MTB SPD's
weastman
7
528
Wed May 11, 2016 10:27 pm
prendrefeu View the latest post
There are no new unread posts for this topic. Lightweight bits n bobs
R350
Mon May 30, 2016 2:33 pm
pdlpsher1 View the latest post
There are no new unread posts for this topic. lightweight & stiff Ti frameset?
addictR1
11
891
Sat Mar 19, 2016 12:32 am
Juanmoretime View the latest post
There are no new unread posts for this topic. Lightweight Mr Pink Builds?
peezy
Fri Oct 21, 2016 8:40 pm
KarlC View the latest post
Users browsing this forum: Baidu [Spider], Bing [Bot], Google Adsense [Bot], jeanjacques, NJ78, sp3000 and 28 guests
