Post new topic Reply to topic  [ 2 posts ]
 Post subject: Integrated headet
PostPosted: Sun Jun 06, 2004 12:51 pm
A Ritchey A-head zero pro. I took away my fork this morning and noticed that it was awfull dirty, after just 2 months of use. Granted, I did a lot of long training rides in the rain. I also noticed the bearings weren't running smooth anymore. Is this normal after 2 months ? Do I need to replace my bearings or headset and most important, if I replace my headset, which one do I choose ? Weight matters of course, but durability also (I still live in Belgium - that means lots and lots of rain). Price is no odject.
I know this is not a 100 % WW question but there is no "technical" forum here ...
 Post subject:
PostPosted: Mon Jun 07, 2004 5:53 am
Integrated headsets are only a means of simplicity at the cost of the frame manufacturers who must assure MUCH tighter machining tolerances on the head tube. Furthermore, it places additional wear on the head tube which is probably one source of the dirt in your headset bearings.
Supposedly, Chris King has a partial solution to the problem. Please see their fact sheet on the technical weaknesses of the integrated headset designs. In my formal and applied engineering experiences applied to the bicycle headset, I find this document to be a valid summation.
http://www.chrisking.com/tech/int_heads ... ain_1.html
Even though the Ritchey uses press-in bearings, it still suffers these weaknesses. More frequent srevice is the only solution.
Users browsing this forum: Doolop, Google [Bot], Google Adsense [Bot], HammerTime2, justinn and 57 guests
There are no new unread posts for this topic. Attachment(s) Integrated Bars
RippedUp
16
1194
Tue May 29, 2012 10:13 pm
cerro View the latest post
There are no new unread posts for this topic. am i going to die? (chinese integrated bar/stem)
fivethirtyonepm
Sat Oct 20, 2012 11:38 am
artray View the latest post
There are no new unread posts for this topic. Storck integrated headset too tight
topcarbon
Wed Jun 13, 2012 12:16 am
Mile Ditch View the latest post
There are no new unread posts for this topic. Question about integrated handlebar/stem systems (140/-17)?
TVQgolf
Tue Jan 29, 2013 9:35 am
Stolichnaya View the latest post
There are no new unread posts for this topic. Chamfered spacer/race/shim for Look integrated headsets
dxs
Wed Oct 10, 2012 10:55 am
dxs View the latest post
It is currently Sat May 25, 2013 7:30 pm
