Post new topic Reply to topic  [ 7 posts ]
 Post subject: stem bar question
PostPosted: Mon May 24, 2004 2:37 am
I got my current rig about a year ago, and for the most part, I like it a lot. However, the more I've ridden it, the more I realize some of the parts spec I was advised upon by my co-workers was (ahem) ill advised. I currently run a deda Mag00 stem with easton carbon bars in 44 width. The bars are the right Recomended size, but I like my bars narrow, so I am going to replace them with a 42. The stem I really like, but I feel like my bars are way too high, and need a bigger drop stem. Does anyone know that the drop angle of a Mag00 is? Also, at this point, I'm thinking about replacing the whole set up with a Kestral carbon bar and larger drop stem, but the only steep angle stem I have found that isn't a total tank is the Deda track stem, but it is 31.8. I like the new syntace F99 stems, but unless the angle is significantly greater than that of the MAg00, i'm not really interested. Any suggestions?
 Post subject:
PostPosted: Mon May 24, 2004 4:00 am
If you stick with 26.0 bars Ritchey WCS still comes in a -17 degree version. 3t and ITM are mostly -10 degree, Deda -8 degree or -6 degree, and Syntace and the newer Ritchey OS stuff is -6 degree.
Compact frames tend to have long head tubes and combined with the trend toward less stem drop it's getting very difficult to get bars low without a using very undersized frame or going custom.
 Post subject:
PostPosted: Mon May 24, 2004 5:03 am
When the threadless stem made its way to the road, stylists decided to replicate the classic lines using a negative angle on the stem with a slew of spacers on the steerer tube.
When I got my Cannondale frame, I set it up based on my Tomasini using a Ritchey 84 degree stem. I found I needed only 6mm of spacers even with 6 degrees of rise. By using such a layout, additional weight is minimized and the stiffness of the setup is increased. But it no longer has those classic lines since the stem angles up significantly.
I still find riders who comment on the off looks. But its much less odd looking than compact frame geometry.
 Post subject:
PostPosted: Mon May 24, 2004 5:28 am
I'm riding a 58 CAAD 7 ('03) its not compact, and there are no spacers at all underneath the stem. I looked at the Ritchey, but I don't think that they make the WCS (the light one) in such a negative rise. I should double check though. Basically at this point, I have about a 3' drop from seat to bars and I need 4' to 5'.
 Post subject:
PostPosted: Mon May 24, 2004 5:45 am
The Ritchey WCS stems can be installed in either orientation. You can get positive or negative. The 84/6 degree stem can be had from 90 to 140mm and the 73/17 from 80 to 120mm in length.
They are light and stiff. You must ride with a low saddle as my setup is about 3" just like yours (56 cm CAAD4, Easton CT2 set at maximum insert, 110mm WCS 6 degrees positive, 6mm spacer).
 Post subject:
PostPosted: Mon May 24, 2004 5:51 am
well, the saddle is about 1" from the max extension line, but the headtube is pretty long, keeping the stem from dropping lower. Basically, the top tube length is perfect for me, but I should have gotten a 56 cause I'm realizing that I prefer a little smaller bike.
 Post subject:
PostPosted: Mon May 24, 2004 5:57 am
actually, i just measured, and I already have a 4" drop, and would like to go to 5-6". Whats funny about this whole thing is that I can probably sell both the Mag00 stem and Easton carbon bars to someone and get the Ritchey/Kestrel setup and have some money left over. thanks for the help.
Users browsing this forum: 573, ferrarista, Google Adsense [Bot], mpower, olmostalegend, philipBer, rijndael and 73 guests
There are no new unread posts for this topic. Attachment(s) CAAD10 headset and stem question
miskur505
18
2324
Thu Jul 19, 2012 6:49 am
Brandonnie View the latest post
There are no new unread posts for this topic. Question about integrated handlebar/stem systems (140/-17)?
TVQgolf
Tue Jan 29, 2013 9:35 am
Stolichnaya View the latest post
There are no new unread posts for this topic. Bike fit question - saddle set back and stem length
Tubby531
10
667
Mon Jan 28, 2013 12:10 am
neeb View the latest post
There are no new unread posts for this topic. HED GTO Stem/Bar
micropox
Sun Jul 22, 2012 9:39 am
micropox View the latest post
There are no new unread posts for this topic. Which stem?
BeeBee30
Fri Jun 01, 2012 7:52 am
SWijland View the latest post
It is currently Tue May 21, 2013 1:13 pm
