Stans no tubes and tire goo
- Contact:
Even if you were to use Stan's or Pit Stop or something similar, that would be adding rotational weight, which is something that might hinder you more than not having to carry a co2. Just a thought.
Most of those things (from memory) are only rated for a couple of months before the tire/the seal becomes useless
But I think someone mentioned when using a Vittoria Pit Stop they only added 11g after repairing a puncture
durarace wrote:Also, I know with mountain bike tires, the sealent does not work well if the pressure is higher then 45lbs. If a road tire were to puncture with 115psi, it probably would not seal until the psi was around 45.
Things like the Vittoria automatically inflate to 90, is thats a help
