Post new topic Reply to topic  [ 4 posts ]
 Post subject: a little wheel quiz...
PostPosted: Tue May 11, 2004 8:36 pm
Regarding lacing of rear wheels (dished, naturally)...
In the past, rear wheels were always laced with some degree of crossing (tangential) of the spokes. When radial lacing became chic, rear wheels always had the drive side laced with a crossing pattern while the non-drive could be radial.
Now we have Mavic Ksyriums, Spinergy Spox R1 and R2's laced with exactly OPPOSITE methodology. The drive side is laced RADIALLY and the non-drive is tangential. There are others too.
And now for the question (essay, no multiple guess, this is an engineering physics question). What made radial drive side lacing possible in a commercial wheel?
PostPosted: Tue May 11, 2004 8:46 pm
Large diameter hub shells that allow the torque to be transferred to the non drive side spokes.
It's necessary with such wheel "systems" because of the lack of room on the drive side for such bulky spokes and their attachment at the hub.
Ride lightly!
 Post subject:
PostPosted: Tue May 11, 2004 8:55 pm
Just guessing.....larger flange on the drive side and smaller on the non-drive side to even out tension?
 Post subject:
PostPosted: Tue May 11, 2004 9:10 pm
We have a winner! Good job, Ye Olde Balde One!
Now for the survey. Has anyone (else) tried this lacing pattern?
Yes, as implied, I have. Not with just any hub/rim combo but with the American Classic 225 hub and 350 rims(back when they were available). I used my employer's solid modeling and FEA software to model the components with pretension of the spokes. Much to my surprise, the static tension of the drive side is most stable at 80% of the non-drive side. When drive torque is applied, the maximum windup for my gearing/weight just causes the tension to equalize.
All DT Revolution spokes with Spline Drive nipples. The spokes, nipples, hub and rim were lubricated on the contacting surfaces with dry film lubricant to prevent galling. Build was uneventful and quite easy with the shop Spline Drive wrench.
After 3+ thousand careful miles, only slight truing was required. My initial concern over spoke/hub fretting on the drive side has not proved to be a problem if the wheels are kept clean. If the spokes get oil/grease on the sockets, the slight windup angle makes some noise but cleaning and reapplication of dry film lube cures this. I just have to keep them clean ;)
Users browsing this forum: Bing [Bot], boolinwall, CBJ, Google Adsense [Bot], Martin.F and 50 guests
There are no new unread posts for this topic. Attachment(s) 3D Printed Disc Wheel Valve Cover with wheel Magnet
RaceWareDirect
Wed Sep 05, 2012 11:04 pm
cyclenutnz View the latest post
There are no new unread posts for this topic. Front wheel 0x, or 2 x
NONAME
7
613
Tue Jul 03, 2012 6:29 pm
MarkMcM View the latest post
This topic is locked, you cannot edit posts or make further replies. Soul S2.0 wheel
addictR1
Sat Jul 21, 2012 11:21 am
Tinea Pedis View the latest post
There are no new unread posts for this topic. Help with Wheel Choices Pls
dvincere
Tue Feb 19, 2013 10:19 pm
Zen Cyclery View the latest post
There are no new unread posts for this topic. Wheel upgrade
montymoo
7
1063
Sat Jul 07, 2012 1:35 pm
montymoo View the latest post
It is currently Thu May 23, 2013 12:22 pm
