Post new topic Reply to topic  [ 8 posts ]
 Post subject: 7800 Crank with Ultegra
PostPosted: Wed Apr 28, 2004 7:31 am
I'm thinking about swapping out my Ultegra crank and bottom bracket for something lighter and stiffer and the 7800 crank came to mind. However, I'm wondering if this is a viable solution or just wasted money. Shimano's site says:
Will the new cranks (FC-7800) work with my current 9-speed set up?
The new cranks are designed to be used with the new front derailleur (FD-7800) and chain (CN-7800). The pickup pins and ramps of the new crank will work best with these new parts.
Are the current 9-speed front derailleurs compatible with the new Dura-Ace crankset (FC-7800)?
No. Only the new Dura-Ace front derailleur is designed to work with the new Dura-Ace crankset.
However, reading cyclingnews' article (link) on Chris Horner's bike it mentions he's still using 9 speed dura ace, but with the 7800 cranks. Any ideas on this possible setup?
 Post subject:
PostPosted: Wed Apr 28, 2004 8:12 am
Dont know about ShimaNo, but Campagnolo makes basically the same claims about their equipment. They say the 9 speed front changer does not work with the 10 speed cranks and that the 9 speed crank does not work with the 10 speed chain. All B.S. in order to sell new equipment. I cant imagine that ShimaNo is any different in this regard.
 Post subject:
PostPosted: Wed Apr 28, 2004 8:55 am
Doesn't R&D stand for Ripoff and Duplication in the Bike market?
 Post subject:
PostPosted: Sat May 15, 2004 6:43 pm
i recently installed the new 2004 dura ace crankset on my klein quantum road bike.All other components are 9 sp and everything works pefectly.I have never hade any problems up to now after about 1000kms and everything works smoothly.
PostPosted: Sun May 16, 2004 9:26 am
hi there,may i know what chain are u using? 9 or 10 speed? Does using 9 speed chain on the 7800 crankset works? How abt the FD ?? pls elaborate more,thanks
italian bikes rules!
 Post subject:
PostPosted: Sun May 16, 2004 1:10 pm
I've used a 9sp cassette on DA10 setup to complete a race (generous friend) and the chain sat well on the 9sp cassette. I would imagine the rings would be less trouble.
I hope that helps.
Brian
 Post subject:
PostPosted: Sun May 16, 2004 1:16 pm
i am using 9 sp dura ace chain with ultegra 9sp casette.my front derailleur is 105 for double shainring crankset.my shifters are ultegra 9sp.rear derailleur also ultegra 9sp.conclusion is that the 9sp chain sits perfectly on the 10sp dura ace cranks.
PostPosted: Sun May 16, 2004 3:24 pm
my plan is same as BigFloppyLlama mention.planing to use this crankset with my current ultegra parts. What are the other stuff that we have to bear in mind?? Does the new DA 10 sp bottom bracket have italian thread? currently now using a Colnago Dream frame.thanks again :o
Users browsing this forum: Google [Bot] and 34 guests
There are no new unread posts for this topic. 7800 & 6600 crank-arm differences
verycreativeusername
Mon Jul 16, 2012 5:05 am
User Name View the latest post
There are no new unread posts for this topic. Replace 7800 Dura Ace crank arms?
trysixty
Sun Dec 16, 2012 3:23 pm
sedluk View the latest post
There are no new unread posts for this topic. Black outer & inner chainring for SRM 7800 Dura Ace crank?
el condor
Sat Sep 22, 2012 10:23 pm
el condor View the latest post
This topic is locked, you cannot edit posts or make further replies. Ultegra Di2 with Sramd Red 2012 Crank?
Fisherfreerider
Sun Mar 17, 2013 8:24 pm
bwdftp View the latest post
This topic is locked, you cannot edit posts or make further replies. crank options for BB30 supersix himod and Ultegra di2?
theStig
Thu May 02, 2013 7:22 am
Omiar View the latest post
It is currently Sun May 26, 2013 6:28 am
