Post new topic Reply to topic  [ 32 posts ]
Go to page 1, 2, 3  Next
PostPosted: Fri Apr 16, 2004 12:01 am
Hi guys!
I got something for yu.
A nice light and stiff wheel for climbers/Sprinters (up to 85 kg no problems)
All build up around the DT swiss RR 1.1 rim.
Here we go.
Rims: 415 x 2 = 830
60 Alu nipples ~ 18 gr
60 spokes: DT Rev spokes and right side rear wheel
Dt Comp Spokes ~ 300 gr.
hubs= tune Mig 66 r/200= 292 gr
or Dt Swiss 240 = 329 gr
On a webpage they claim the one with tune hubs with 1380 gr. So the Dt Hügi one must be just a little over 1400 gr. Not bad huh?
The rim is really good and stiff. Yu get that thingy over here around 500 Euros.
I really think i gonna sell my SL`s and buy this thingy... :oops:
 Post subject:
PostPosted: Fri Apr 16, 2004 2:09 am
Got some very recently myself with CX-Ray spokes and 28h Record hubs. Total weight should be in the region of 1500 or a little less....
 Post subject:
PostPosted: Fri Apr 16, 2004 3:35 am
Care to give us a little review? :wink:
MAMA SAID KNOCK YOU OUT! HUH!
 Post subject:
PostPosted: Fri Apr 16, 2004 9:45 am
Hmm looking good.... :shock:
The heavy part of your wheels are the hubs 385 gr for record hubs. The spokes are a little lighter maybe 10 gr overall. So the difference isnt that big.
What about stiffness? Ive heard the sapim spokes are a little..lets say naughty..hehe.
Oh and please post a full pic of the wheels...thx 8)
 Post subject:
PostPosted: Fri Apr 16, 2004 11:12 am
Hey guys...i just ordered my new wheelset. (now i am selling my Ksyrium SL`s ..heh)
This set is stiff, solid and damn good locking.
Rims: Dt Swiss RR 1.1 <<<830 gr (2 pcs)
hubs: Tune Mig 66r/200 <<292 gr
nipples: Dt prolock <<<<< 18 gr (56 pcs)
spokes: DT aerolite<<<<<244 gr (56pcs)
___________________________________
~ 1384gr
I talked to a wheelbuilder and he said the aerolite spokes are the best spokes out there right now. Light and really stiff and very well made.
I post some pics if they are ready.
 Post subject:
PostPosted: Fri Apr 16, 2004 12:16 pm
Personally, I haven't heard of anything stating the Aero Lites are better than CX-Ray. I would have tried them however for this set if they were available in silver as well.
I haven't ridden the wheels yet as they're for my new bike I'm currently building up. I got an almost similar set but with OP rims instead. They're quite stiff yet smooth riding, stay very true, and are strong. However, in comparison the DT Swiss rims are definitely of a higher quality. They are rounder, more consistent, the weld is much smoother, and general finishing is of a higher standard. Nice touch are also small wear indicator dimples in the braking surface.
I'm not a real weight weenie but like quality stuff that's reasonably light and still durable. In that respect the Record hubs are almost unbeatable in my opinion. You may wonder why I read this forum then? Simply put, because weight weenies tend to know their stuff very well and are often aware of the latest developments :)
 Post subject:
PostPosted: Fri Apr 16, 2004 1:14 pm
Well i dont know if the spokes are better i just can tell yu what this guy told me.
Btw i chosed 28 spokes for front (radial) and rear (3x/2x)
 Post subject:
PostPosted: Fri Apr 16, 2004 1:20 pm
I went for:
28h RR1.1
28h Record F+R hubs
CX-Ray spokes + Polyax alloy nipples
Lacing 3x everywhere
 Post subject:
PostPosted: Fri Apr 16, 2004 1:30 pm
Very solid too. Can yu take a full pic of your Wheels please? Curious... :oops:
 Post subject:
PostPosted: Fri Apr 16, 2004 3:11 pm
Not sure what additional info you will see :?: Maybe you just want me to prove I actually own the wheels :lol:
....full wheel pics normally don't look very good unless you use a typical studio background and line them up like Mavic does for instance.
BTW, haven't gotten round yet to taping the rim and sticking on the rear tire.
 Post subject:
PostPosted: Fri Apr 16, 2004 3:22 pm
BTW, for what it's worth make sure your builder gets the lacing right on the rotor side. The trailing spokes inside flange and leading outside. Reasoning is that when you torque down the inside trailing spokes will pull straighter and leverage the leading spokes to the inside so there's less chance of the derailleur getting caught when in the large cog. The other benefit is that if you over-shift (shouldn't normally happen :) ), the chain will tend to pull out instead of in due to the outer spoke direction.
....this is just general theory...some say it makes no difference....but why not rather safer than sorry?
 Post subject:
PostPosted: Fri Apr 16, 2004 4:08 pm
Hey thx for the full pics. I just wanted to see the whole wheel with all spokes and stuff for the general look. and impression that wheelset got and it looks jolly good. My
Yu can have a look at the builders webpage ...well its german but well...
www.whizzwheels.de
 Post subject:
PostPosted: Fri Apr 16, 2004 5:06 pm
~ 1384gr
Why the Dt Swiss RR 1.1??
Is it stiffer than de mavic open pro? Or other rims?
With the open pro it would be 1404gram for the wheelset.
With the mavic CXP 33 it would be 1494gram. Yeah to heavy but they are stiff just like the ksyrium SL
 Post subject:
PostPosted: Fri Apr 16, 2004 6:16 pm
Alot stiffer than the Open Pro....
btw divve what about the stiffness of yopur wheelset? And whats your weight? :?
 Post subject:
PostPosted: Fri Apr 16, 2004 7:10 pm
HäddaFahn,
I've heard about the Whizz guys. They build excellent wheels.
I don't know whether the DT rims are stiffer. They have a slightly higher box section than OP so it might be. I did noticed that the spoke tension on my DT set is a bit higher compared to the OP set. From what I remember Mavic doesn't recommend you go over 110Nm, which is a little low when compared to "system" wheels, haven't noticed any problems with OP however. I weight about 167lbs and am 6' 0.6"
Paul, the DT rims are on average 10-20g lighter than the OP rims. Grab a series of 10 at a shop and weight them. You'll find that the DT weights are much closer to spec than OP. The latter are sort of all over the place. General manufacturing quality of DT rims is also better.
Post new topic Reply to topic  [ 32 posts ]  Go to page 1, 2, 3  Next
Users browsing this forum: Bing [Bot], bugmenot, CSKeller, Google [Bot], jasoncd, jdott, tommasini and 61 guests
This topic is locked, you cannot edit posts or make further replies. alloy road clincher rim? stiff yet light?
durianrider
Mon Jul 16, 2012 10:16 am
Tinea Pedis View the latest post
There are no new unread posts for this topic. Laterally Stiff Wheelset
semaj
Fri Aug 10, 2012 11:35 pm
mr_tim View the latest post
There are no new unread posts for this topic. Stiff and Cheap carbon tubular wheels ?
CeCa
Tue Jun 05, 2012 12:15 am
strobbekoen View the latest post
There are no new unread posts for this topic. zipps newest 202s are they stiff enough for field sprints?
JAX11
Tue Jun 19, 2012 3:16 pm
Zigmeister View the latest post
This topic is locked, you cannot edit posts or make further replies. Laterally stiff, mid-high carbon rear wheel
ultyguy
Thu Jul 12, 2012 9:49 am
ultyguy View the latest post
It is currently Thu May 23, 2013 4:22 am
