ergott wrote:I'm trying to help you out here. This forum is filled with people who are very analytical. They are not usually satisfied with statements that are not backed up with imperical evidence. This is moreso the case when someone makes a statement that might be contrary to more common ideas (right or wrong). When you post your findings, you are greated skeptically because you do not elaborate on your findings. There are enough people here that are intelligent enough to follow you when you get technical. They would appreciate you giving as much detail as possible. I'm sure you would if it weren't for restrictions put on you buy the purchaser of the data you have collected. It might be better to either leave out the vague posts all together or maybe explain with as much detail as you can without violating your aggreement. You should be able to post numbers if ou don't mention manufactureres. You could label the wheels A and B and describe them. Don't treat members like they would not understand you.
-Eric
eric you know i respect you
i simple ask a question
did not treat any one
and release data from a wheel test was a totaly differant tread
this is totaly about something else
there are people who hear about let say suits that reduce drag and given by grams
my simply question was how many poeple know this nothing more or less
what others make out of it is beyound me
this tread is about 1 gram drag and what it means in performance!
