It is currently Tue Dec 12, 2017 11:36 am
Post new topic  Reply to topic  [ 28 posts ]  Go to page Previous 1 2
 Post subject:
PostPosted: Sun Apr 11, 2004 12:04 am
Quote:
The Cannondale is lugged, there are only 2 ways Lugged and Monocoque. The Oxford dictionary defines lug as fixed in place. The carbon is fixed in place. even if you build a frame and then cut out the sections, what you are left with are lugs.
So dose that mean my shoes are lugged when fixed in my pedals place? Or how about my wheels, there fixed in place, so they muct be lugged to!
That definition is pretty broad, with it, if you take it word for word as you have pretty much everything in the world is lugged. The definition doesn't really apply directly to bicycle, just in general.
I spoke to the cannondale rep, he gave me very detailed information about the frameset. Even he told me that it is not lugged, as cannondale claims their method is far supperior to lugged frames.
Quote:
It would still be possible to take the two materials apart once in the frame
No it isn't, as the bond from aluminum to carbon is both a mechanical and chemical bond. Lugged frames only have chemical bonds, not mechanical. I held a chopped up six 13 in my hands, and saw the mechanical bond.
Heres a pic, notice the whole rear triangle, pretty much one piece. If there is a lug on the bike it is the head tube, but it isn't because the aluminum is all welded together and then seemlessly transfer into carbon.
 Post subject:
PostPosted: Sun Apr 11, 2004 1:58 am
I am not looking for a fight and not looking to offend but I have been biting my tongue too long on this one.
What does the mechanical bond have to do with being or not being lugged? If I make a lugged joint and then run a screw through its still lugged isn’t it? But is also mechanically bonded. Heck, that’s what the old art of pinning a steel lugged frame was about.
I see this bike as welded aluminum lugs regardless of whether they were welded up complete and cut apart or not.
The carbon tubes are fabricated (molded) in place, inside these lugs. The lugs have a couple little holes cut in them so the carbon has a bit of a “hook” (SL’s mechanical bond)
Now let me point this out, all of the welded aluminum lugged carbon frames (ala trigon) are aluminum and carbon tubes bonded then mitered and finally jigged and welded. Are they lugged or not? Who cares!
Doesn’t matter what you call it, its still aluminum intersections glued to carbon tubes with a little help of a mechanical thingy.
All it really means is that if you break a tube you can toss the frame cause there is no way they are going to put it back into the production line to have a new tube formed into it.
This is also still quite a bit different than isogrid where there is a matrix of ti running the full length of the tube. The cannodale has no alum between the intersections of the main triangle
My 2 cents
ps, how many of the people arguing this have taken the time to run through the marketing material on this topic at the legalize my cannondale web site?
How much does it weigh cause thats all that really matters here.
www.crumptoncycles.com
 Post subject:
 Post subject:
PostPosted: Sun Apr 11, 2004 7:11 am
As for the headtube not being a lug because it is welded together, do you seriously think that manufacturers of lugged bike machine an aluminium lug out of a solid block of aluminium.
And if you listen to a Cannondale rep and take that as gospel......
Trek use a mechanical bond for the joins, so this is not new. My backpack uses a mechanical bond for its straps. even if I had to glue the clips together, I could still heat up or dissolve the glue, unclip and would still have 2 disstinct pieces.
Same with cannondale six13
As for weight
Please legalise my Cannondale? this thing is over 1100 grams, and with Cannondales track record, that means probably more. Not even close to being light.
They should rather focus on their traditional stronpoints which are Stiffness and sharp handeling. As for looks, that is personal. But Cannondale just look like a normal bike with chunky tubes.
 Post subject:
PostPosted: Sun Apr 11, 2004 8:14 am
Have you ever ridden a Cannondale? They focus on exactly what you said, stiffness and handling. Why do you think their frames are 1150g for the six13 and 1250g for the CAAD7? Weight is not their goal, rideability is. Weight comes second with them.
 Post subject:
PostPosted: Sun Apr 11, 2004 10:06 am
But if weight is not their goal, what do they want with their "legalize....." campaign? Proof, that you can build up a light complete bike with a (compared to some other carbon frames) relatively heavy frame?
I think this campaign is quite ridiculous.
 Post subject:
PostPosted: Sun Apr 11, 2004 10:50 am
I think the Caad 6 was the last stiff Cannondale frame. The Caad 7 feels very italian wobbly as does Pinarello, Opera, Vinder, De Rosa and so on...
Caad 6 felt like Klein Q pro, Principia and Boreas. Quite a change in direction. Which dale has admitted in pressreleases regarding the caad 7 last year.
 Post subject:
PostPosted: Sun Apr 11, 2004 5:49 pm
correct me if i'm wrong but CAAD6 was a caad5 frame with the integrated crankset. (i recall this because i thought everything after caad6 was going to have the integrated bb, and i work at a shop)
and they stopped the confusion by going to caad7 which you can get in either bb. and was renamed to optimo.
 Post subject:
PostPosted: Sun Apr 11, 2004 5:51 pm
First year of CAAD7 was not optimo, second year cannondale started using optimo tubing to save 15% weight.
 Post subject:
PostPosted: Sun Apr 11, 2004 5:57 pm
http://www.cannondale.com/bikes/innovation/caad7/
i know it was called caad 7. then they changed to optimo and i recal hearing it was lighter then caad7, but accordign to their site its the same thing.
Quote:
caad7 uses our all new optimo alluminum alloy which boasts 15% greater tensile strength then regular aluminum
[/quote]
 Post subject:
PostPosted: Sun Apr 11, 2004 6:54 pm
That's incorrect. Check the below link:
http://www.cannondale.com/cog/02/caad7.html
Quote:
The official debut of the CAAD7, scheduled for early 2002, will mark the first time that Cannondale has used any alloy other than 6061-T6 aluminum. The CAAD7's new, proprietary aluminum alloy will allow Cannondale to use thinner, weight-saving walls in selected tubes without compromising strength. Creatively manipulating the shape of the tubes will also ensure that the CAAD7 has Cannondale's trademark efficiency, light weight and comfort.
 Post subject:
PostPosted: Tue Apr 13, 2004 8:49 am
@ mrowkoob:
I've ridden both CAAD 5, Pinarello Prince and De Rosa Merak (2002) : there's no way the Cannondale could be stiffer than (those) italian bikes...
Prince is stiffer, more reactive and more "compact" (i don't know exact word: I mean it seems to be a single piece instead of tubes welded toghether) ; De Rosa is stiffer too, but it lacks something on rough roads, it's stiff but not so resistant...
Cannondale is a great bike, but not so reactive as other two... but it's lighter than Pinarello (very much lighter)...
Notice that i use very compact sizes, so things may be slightly different in bigger sizes...
Bye, Benz.
 Post subject:
PostPosted: Tue Apr 13, 2004 11:02 am
They must be since I ride size 60 and 61 and have exactly the opposite experience.
 Post subject:
PostPosted: Tue Apr 13, 2004 2:49 pm
I ride 48-49 sizes...
I've heard also of reliability problems with Prince as big as your size (riders who broke 2 or 3 frames within 18 months !!)
WHEN THE SIZE DOES MATTER...!!
Bye, Benz.
There are no new unread posts for this topic. Campag reach adjustments for small hands
bikewithnoname
Sat Oct 21, 2017 5:35 am
Mr.Gib View the latest post
There are no new unread posts for this topic. Cannondale Six13 Frame Weight
Sizzler
Sun Jan 08, 2017 7:19 pm
KC View the latest post
Users browsing this forum: Google [Bot], Google Adsense [Bot], Shrike, stormur and 26 guests
