Zero-Gravity brakes 177g....
nino
by nino
i just installed those brakes 2 weeks ago and they are really beautiful.187g is already a very light weight but i just replaced the standard pads with some others and lost 10g in the process....my brakes now weigh just 177g and are more powerful than before!!
the standard Z-G pads are made by Kool-Stop but are supposed to work on carbon rims.since i use aluminium clincher wheels (Amclassic CR420) the pads just didn't deliver that sort of brakepower i was looking for. i just mounted some Kool-Stop MTB pads.they fit perfect but are longer than road pads.i just cut off the excess lenght - now they look perfect.
standard Z-G pad weight (4 pcs.): 26g
shortened MTB Pads (4 pcs.): 16g
here's the picture of the brakes with standard pads installed.note the extremely thick pads:
Superlite
by Superlite
What pads did you use? Got pics? I think the stopping power is great with provided pads, is it that much better with yours?
nino
by nino
i just had some black Kool-Stop MTB pads around.they are more powerful than the standard ZG pads.
Kool-Stops are well known to be powerful on aluminium rims.black Ritchey pads would also be a good choice.
anyway - any MTB pad will fit.all you need is cut off the excess lenght (ca. 10mm).
ZeroLite
by ZeroLite
I am getting wet!!!!
I want your input.
