Stronglight Pulsion...bit of a structural failure!
snips
by snips
On the way to race this afternoon, put the power down away from some traffic lights and BOOM...bits of chainset all over the road.
Everything torqued up properly and no damage. One tab breaking would be bad but for three to go...I'm speechless (and also lost a Tune chainring bolt whilst trying to get chainring on in a state where I could hobble home...rats).
col hicks
by col hicks
that sucks it makes me not want to ride mine
Ramjm_2000
by Ramjm_2000
Wow! :shock: Makes me glad I went with the Vulcans. Let us know how/if stronglight takes care of the problem.
Rich_W
Location: On an Island 6 Miles at Sea. Move over Smithers, I'm drivin...
by Rich_W
lovely... those new record cranks can't come out fast enough...
were you getting any funky creaking before they failed?
flying
by flying
Is it possible the Tune chainring bolts allow some play? Or are they the exact same size at the pulsion bolts?
Sorry you had a problem but glad you were not hurt.
strobbekoen
by strobbekoen
drjones96 wrote:Haven't we seen this same sort of failure before?
Indeed, i am sure i saw it before too, not sure where though
ergott
by ergott
Hope you're ok.
Check the right chainstay to. It looks like there is a gouge in it.
-Eric
snips
by snips
Tune bolts were an exact fit and, as said, torqued properly.
Had no indication that it was going to break either, ie creaking or movement, it just literally exploded! I was fine...was a bit of a hassle limping back home though.
I imagine one tab failed then the others failed as the chainring twisted and moved. Its going in the post to France tomorrow...
Oh and the marks on the chainstay is in thick protective plastic which I've stuck there... it's the old mountainbiker in me that causes old habits to die hard :)
strobbekoen
by strobbekoen
check out this old topic
http://weightweenies.starbike.com/forum/viewtopic.php?t=10033&highlight=pulsion+broken
apparently, the guy broke it while pushing down the power at a traffic light........... :shock:
jeremyb
by jeremyb
my pulsions are thin around that area as well. Should I send them to Stronglight? I didnt buy them new.
Maybe I should beef up the area with a little extra carbon and some epoxy?
j
