Are Zero Gravity pad holders Campy compatable?
The reason I ask is that I just ordered a set of Swiss stop yellow carbon pads in Campy version. They looked a little thinner than the std Corima cork pads, but I didn't think anything of it until they fell out when I was rolling my bike backwards in the car pack and applied the brakes!!!
That scared the hell out of me, so it's back to Corima for now. Should I be ordering the Shimano version? I thought ZG's were Campy style.
Cheers
Cheers
Long live long rides
Yes, the 0G do only take Campa-style brake blocks.
I agree on the relatively loose fit though. My brother has once lost a yellow Swissstop due to that reason. I have been using some Dynamic mounting paste last time I installed them, but would probably advice to try out a drop of tubular glue.
| works for an European bike manufacturer |
| "I respect the work in coloring parts but the result is stupid-monkey in silk clothes is still monkey." |
I'm using original Campy carbon pads in ZG. I had to use considerable force to insert them. Maybe Swissstop are a little undersized.
The Corima pads can come out too if you brake backing up. Either use glue or never brake baking up.
For certain parts stiffer is more important than lighter.
OK, It's reassuring to know that I'm not the only one. I don't really want to use glue, as I'm swapping the pads up to once a week in the Summer. At least I shouldn't have difficulties getting them out
divve wrote:Maybe Swissstop are a little undersized.
Swissstop definetly slide into a normal Campag holder easier than the Campy pads do.
I think that ZG has changed their holders just a bit. It definitely takes less effort to change pads than on older models.
