Post new topic Reply to topic  [ 24 posts ]
Go to page 1, 2  Next
 Post subject: Its finally done!
PostPosted: Fri Mar 26, 2004 5:22 am
The Kuota is finally finished. The complete parts list is below. The total weight built came out to 13.16 lbs. Quite a bit less than the list indicated. I was hoping for under 13 lbs., but I guess 13.16 lbs is not to bad considering the frame weighs 3 lbs.
Weight (g) Notes
Frame Kuota Khan 57cm 1300 True Weight
Fork Storck Stiletto Light 361.9 True Weight Uncut
Head Set Tiso Joe Grafite (1 1/8'') 60.2 True Weight
Head Set Spacers Kuota Carbon 19.6 True Weight
Expander and Top Cap Tiso 33.3 True Weight
Seat Post AX Lightness 125.5 True Weight
Seat Post Shim Alien 16.3 True Weight
Seat Post Clamp Kuota 22.1 True Weight
Saddle San Marco Aspide Composite Ti 114.4 True Weight
Cranks Storck Power Arms 323.5 True Weight
Chain Rings: 53 Tooth TA 88 True Weight
35 Tooth TA 34.3 True Weight
Chain Ring Bolts Tiso 9.2 True Weight
Crank Fixing Bolt Tiso 14.8 True Weight
Stem Kuota Carbon 109.3 True Weight
Bars Easton EC90 44mm 206.5 True Weight
Bar Tape Kuota 49.4 True Weight Uninstalled
Bar Tape Holders 8.4 True Weight
Levers Campy Record 04' 326.6 True Weight
Shifting Cables Metawire 91.7 True Weight
Cable Stops Kuota 7.3 True Weight
Brake Calipers Zero Gravity 188.7 True Weight
Brake Cables Metawire 109.1 True Weight
Front Derailleur Campy Record 04' 70.5 True Weight
Front Derailleur Frame Clamp Kuota 24.2 True Weight With Screws
Rear Derailleur Tiso 178.6 True Weight
Wheels American Classic Carbon 1130 True Weight
Front Tire Tufo S3 Lite 145 145 True Weight
Rear Tire Tufo S3 Lite 160 160 True Weight
Valve Extenders Tufo 23mm (Pair) 3.9 True Weight
Skewers FRM Pro 2 64.1 True Weight
Cassette Tiso K27 134.8 True Weight
Lockring Tiso 5.5 True Weight
Chain KMC X10 (116 Lincs) 262.1 True Weight
Bottom Bracket Phil Wood Titanium 140.5 True Weight
Bottom Bracket Cups Phil Wood Titanium 14.8 True Weight
Pedals Speedplay X-1 w/ Superlite Inserts 134.1 True Weight
Bottle Cages Elite Ciussi Patao Carbon (2) 65.4 True Weight With Screws
Total: 6153.6
 Post subject:
PostPosted: Fri Mar 26, 2004 5:31 am
Congratulations!
Ride lightly!
 Post subject:
PostPosted: Fri Mar 26, 2004 5:43 am
Can you post a pic for us to drool over?
Brian
 Post subject:
PostPosted: Fri Mar 26, 2004 6:06 am
Here are the pics.
#1
 Post subject:
PostPosted: Fri Mar 26, 2004 6:08 am
Very nice JTC! Looks like theres even more weight to be taken off.
Get some schmolkies and save 40g!
Get an Easton EC90 SLX SL and save another 60-70g, then you'll be sub 13lbs!!!
SICK MAN, SICK! :twisted:
MAMA SAID KNOCK YOU OUT! HUH!
 Post subject:
PostPosted: Fri Mar 26, 2004 6:09 am
#2
 Post subject:
PostPosted: Fri Mar 26, 2004 6:12 am
Pimp!
You should get rid of the red tape and tire and go stealth with all black. Just my opinion.
Thats a beast, I really like that frame, is it stiff or what? if you don't mind me asking how much did the frame run?
 Post subject:
PostPosted: Fri Mar 26, 2004 6:16 am
#3
 Post subject:
PostPosted: Fri Mar 26, 2004 6:30 am
#4
 Post subject:
PostPosted: Fri Mar 26, 2004 6:32 am
Very nice JTC. I've never seen seatstays like that.. can you take a closer pic of the seatstays? It looks like they rake forward at the point the brake attaches ..?!
 Post subject:
PostPosted: Fri Mar 26, 2004 6:33 am
#5
 Post subject:
That last photo is close but I mean one from the side profile..
 Post subject:
PostPosted: Fri Mar 26, 2004 6:43 am
Yeah, I know, but I really love the shape of these bars.
Yes, I was dissapointed after receving the fork and it weighed 360g, but that was uncut with a rather long stear tube and there is no need for an expander plug as it is built in which eliminates weight also. I think the EC90 SLX Sl is 300g cut to 200mm if I am not mistaken.
I've had it a while so I have forgoten the exact price but the frame and original Kuota fork were around $2200-2400.
 Post subject:
PostPosted: Fri Mar 26, 2004 6:49 am
Side view
 Post subject:
PostPosted: Fri Mar 26, 2004 7:52 am
Nice job, wow!
Did you buy the Tiso stuff in US or overseas (I don't know where you are located)?
"Gimondi è un eroe umano, che viene sconfitto ma che continua la sua corsa fino a tornare a vincere." - Enrico Ruggeri
Post new topic Reply to topic  [ 24 posts ]  Go to page 1, 2  Next
Users browsing this forum: Bing [Bot], CarpetFibre, cyclistcong, Google [Bot], Google Adsense [Bot] and 54 guests
There are no new unread posts for this topic. Is the EE Crank a finally a reality
DamoRider
Thu Dec 20, 2012 1:17 am
djconnel View the latest post
There are no new unread posts for this topic. Finally the rim I've been waiting to talk about.Pacenti SL23
[ Go to page: 1 ... 4, 5, 6 ]
ergott
75
6691
Fri Apr 05, 2013 2:37 pm
madcow View the latest post
There are no new unread posts for this topic. Campy Finally Releases EPS Integrated Battery System!
audiophilitis
Tue Apr 02, 2013 7:32 am
doomith View the latest post
It is currently Mon May 20, 2013 8:56 am
