Post new topic Reply to topic  [ 3 posts ]
 Post subject: Zipp wheels
PostPosted: Sun Mar 21, 2004 12:52 am
I have resently bought a pair of Zipp 404s and I have now discovered that there is a little bit of play in the rear hub. :( Is it something I can fix myself and how is it done?
I have tried Zipps homepage but I could not find anything helpful there.
Pain is weakness leaving the body.
 Post subject:
PostPosted: Sun Mar 21, 2004 10:24 am
Use a pair of cone spanners to:
Unlock the cone and nut,
adjust/repack the cones,
lock the cones into place.
It's relatively simple and with experience it's something that becomes second nature.
If you are repacking the bearings just make sure it all goes back in as it came out :wink:
Happy repairs
Brian
 Post subject:
PostPosted: Mon Mar 22, 2004 3:25 pm
The Zipp 404s have cartridge bearings and so cannot be adjusted as Bruiser suggested. To change the preload on the bearings you need two 5mm hex wrenches. These insert into either end of the axle and allow you to change the bearing preload, remove the free hub or change the axle.
When you clamp the wheel into the bike the quick release skewer will apply additional pressure to the bearings as it clamps against the dropouts. You need to adjust the preload using the hex wrenches, replace the quick release, clamp the wheel to the bike, check the play in the bearings and then repeat until the preload is correct.
I hope this helps
Chris
Users browsing this forum: 1415chris, Bing [Bot], Google [Bot], Google Adsense [Bot], jooo, LionelB, mellowJohnny, shoopdawoop and 59 guests
There are no new unread posts for this topic. Zipp 11 speed wheels and the strange answer from their CS
goodboyr
7
1137
Sat May 11, 2013 4:11 pm
goodboyr View the latest post
There are no new unread posts for this topic. Some rambling about wheels - Campagnolo Neutron and Zipp 101
jasoncd
Wed Jul 25, 2012 10:46 am
sawyer View the latest post
There are no new unread posts for this topic. Zipp wheels conversion to Shimano 11sp
DKTYO
Fri Jan 04, 2013 4:13 pm
CharlesM View the latest post
There are no new unread posts for this topic. Rim-fork width probs with Zipp or Bontrager Aeolus D3 wheels
dragon76
11
689
Wed Aug 22, 2012 7:13 pm
ajxd View the latest post
There are no new unread posts for this topic. zipp 303 FCC Front / zipp 404 FCC Rear
jameskack
Mon Sep 10, 2012 8:10 pm
dmoneysworks View the latest post
It is currently Wed Jun 19, 2013 5:27 pm
