Post new topic Reply to topic  [ 19 posts ]
Go to page Previous  1, 2
 Post subject: Re: Tubulars
PostPosted: Mon Mar 22, 2004 4:41 pm
I used to have the same problem with snow and sleet with the old, red Clement tubular glues. The newer product appears much 'stickier'. Upon removing the damaged tubular, you will find that the 'new' tubular will stick nicely once up-to-pressure. The do stick faster when it is warm, though. The best glue that I have found (for all tires, including Continentals) is Vittoria Mastic One. Mastic One goes-on very cleanly and is very sticky in the wet.
Since you will eventually get a 'stash' of used, undamaged tubulars (since they rarely flat), you will get a pile of very useable spares with an adequate amount of old glue remaining on them. If not, don't forget to pre-stretch your spares (stretch them by looping it around your foot then pulling-up hard, rotating around the tire, then install on an old rim and inflate to pressure for a few days - a week is better. Oh, clean the old rim as well as you can. You will find that the old glue remaining, even if it is years old, still is sticky enough to make a new, unstreched tubular difficult to remove), inflate it slightly to turn the base tape up, put a thin layer of glue on the base tape and let it dry well. The thin layer of glue will help the tubular stick, even in the snow.
 Post subject:
PostPosted: Mon Mar 22, 2004 9:50 pm
Thanks for that Geoff, I'll be giving sprints and tubs a go this year - in prep for a new bike next.
PostPosted: Mon Mar 29, 2004 12:51 am
No problem. Tubulars will change your life :wink: .
What do you ride and what bike are you building next?
 Post subject:
PostPosted: Mon Mar 29, 2004 6:01 pm
What do I ride - something from a mainstream UK manufacturer, approx. 7 years old (although in good condition because it was in store for 5 years - an end of season bargin) and very heavy :oops:
I bought some scales a couple of weeks ago, weighs to 1kg in 1g and 2kg in 2g, so when I gave my bike a mini-service the other week I weighed a few bits. How do these grab you?
Forks (steel - ouch) 786g
f wheel 858g
r wheel 1060g
QRs (pair) 168g
brakes (pair) 389g
tyres (pair) 740g (heavy ones to resist winter punctures)
The only light bits are the tubes (pair) 165g, although the saddle (Mission - who they? but very comfortable) at 243g is not too far off of some WW's choices.
Total weight somewhere around 23 lbs.
However, the fun starts late this / early next year - building a light(er)weight bike. Unlike a lot of the WWs (or so it seems to me) my finances will not allow the very lightest, coolest gear, so it will be a case of balancing cost against weight savings. That will be fun :roll:
How does this grab you for a topic - 'WW on a budget!'?
At least it won't be black, cause I cannot afford full carbon.
Post new topic Reply to topic  [ 19 posts ]  Go to page Previous  1, 2
Users browsing this forum: Dalai and 34 guests
There are no new unread posts for this topic. last tubular flat?
Monkeyboy3333
20
1016
Mon Apr 15, 2013 3:45 pm
bjorn240 View the latest post
There are no new unread posts for this topic. stem top cap thats flat
digitalnorbs
19
1690
Thu Nov 08, 2012 2:12 pm
drchull View the latest post
There are no new unread posts for this topic. Attachment(s) hand pump after a flat
project3
43
2203
Mon Mar 25, 2013 12:44 am
project3 View the latest post
This topic is locked, you cannot edit posts or make further replies. 2 Tubulars - Which would you buy and why?
ricorob
Sat Aug 04, 2012 2:02 pm
gilesharrison View the latest post
There are no new unread posts for this topic. Which fork will clear my new tubulars?
Kastrup
Sun Oct 14, 2012 6:25 pm
LionelB View the latest post
It is currently Sun May 19, 2013 1:52 pm
