It is currently Sat Jan 20, 2018 12:30 pm
Post new topic  Reply to topic  [ 28 posts ]  Go to page 1 2 Next
PostPosted: Fri Apr 28, 2006 4:51 am
I have about 10 rides on my new Pulsion Stronglight crank. After several rain rides I had a little creak going on so I thought I would pull off the cranks and BB and grease everything. While loosening the crank with the self extracting crank bolts, the bolt and self extracting assembly just ripped all the threads off the crank arm and fell off. Not only is the crank ruined, but I think the only way to get it off is the cut the BB spindle beween the crank and the frame. I bought the cranks on Ebay. Anyone know if I can warranty these and how? I live in California. Has this happened to you???? I tried to add a picture, but it weightweenies says my pic is too large, sorry
 Post subject:
PostPosted: Fri Apr 28, 2006 5:17 am
You can upload pica at tinypic.com for free and without registration. (big pics will be resized)
Whow! That's a pretty damn nice garage door!
 Post subject:
PostPosted: Fri Apr 28, 2006 5:19 am
You may be able to get a small claw puller on it and get it off. Of course now that it's on, you can leave it on. If the puller works, you can always use that method if it means tossing the cranks.
 Post subject:
PostPosted: Fri Apr 28, 2006 5:23 am
ebay is always a sticky situation with manufacturers. techincally, you need to purchase them through an authorized dealer. so, sorry to say, but it probably isn't going to be warrantied. i'd contact your local shop and find out if they work with J&B importers. Contact the local J&B rep. to see what he/she may say. they're the dist. for the cranks in america
 Post subject:
PostPosted: Fri Apr 28, 2006 7:06 am
Why do you buy such an item on Ebay. Just support your local dealer, in the end it is so much cheaper.
K
 Post subject: dura ace
PostPosted: Fri Apr 28, 2006 7:13 am
You are right. I think I may just add 160 grams and go with trouble free Dura ace. Man 160 grams sounds like hell.
 Post subject:
PostPosted: Fri Apr 28, 2006 9:22 am
The only self extracting bolt that works well is Dura Ace 7700. FSA will end up like Stronglight.
 Post subject:
PostPosted: Fri Apr 28, 2006 9:30 am
Administrator
Somthing on this this doesn't sound right. I just don't like selfextractors plus the FSA alloy bolts are 16 grams lighter. I've had my Stronglight Pulsion CT2's for about a year and have taken them off a couple of times without issues. Although I did get rid of the self extractors and just use a regular puller.
RESIDENT GRUMPY OLD MAN.
 Post subject:
PostPosted: Fri Apr 28, 2006 10:11 am
try not to panic about this. Have you heard of helicoils? Roughly you smooth the hole out by drilling /reaming (it'd be heaps easier with the crank off tho) then threading the crank...but "1 size up". The helicoil is like a spring that screws into THAT (new) thread created by the inside of the spring. I have never tried it with something as large as the crank extractor hole...but it should still work. Most engineering shops will have helicoils (or what ever the local equivalent is). The top quality ones are guaranteed to be as strong as the original thread I think. Talk to your local engineering workshops...but try a consult with real engineers here.
Updated: Racing again! Thought this was unlikely! Eventually, I may even have a decent race!
Edit: 2015: darn near won the best South Island series (got second in age
-group)..woo hoo Racy Theremery is back!!
PostPosted: Fri Apr 28, 2006 12:16 pm
Resident Pro
this may be a silly question, but did you make sure to remove that black dust cap before trying to remove the bolt? you have to have a modified shimano dustcap remover to take it off, and only then you can remove the bolt.
 Post subject: try VAR
PostPosted: Fri Apr 28, 2006 12:24 pm
VAR makes (or made)a crank puller that leverages off the stays rather than pulling the arm off the BB. If you go to an older or well-established bike shop, they may have one in stock. Alternately, it can be pried off with a big bar, but that may ruin the frame. Last option: take the bolt out and ride it around until it loosens. This will wreck the arm, though.
You might be able to put in a helicoil, but crank extraction will be iffy in the future.
 Post subject:
PostPosted: Fri Apr 28, 2006 3:14 pm
Durarace,
Honest question: What torque did you use when installing the Pulsion crank on those splines?
This thread has me worried. I have a set of Stronglight Vulcans to put on. Does the dust cap unscrew counter clockwise, once those 180 degree opposing holes have the Shimano tool sunk into them? I couldn't figure out how to get it off when I was weighing my Vulcan compact (512gr, with cap/bolts). BTW, I went to the Park Tool site and didn't pickup what they meant regarding self-extraction, how to seperate the bolts from the crank, etc.
I know, call me stupid :?
Chris
 Post subject:
PostPosted: Fri Apr 28, 2006 3:22 pm
Resident Pro
wogamax wrote:
Durarace,
yes dustcap must be removed counter clockwise. after that, remove bolts counterclockwise.
mike
Chris
PostPosted: Fri Apr 28, 2006 7:45 pm
I thought the cap WAS the self extractor. If you take that off, then the self extrating mechanism would not work and you would have to use a regular puller right?
 Post subject: torque
PostPosted: Sat Apr 29, 2006 12:06 am
Wogamax,
As far as torque goes, I did a search on weightweenies and read in several threads that with ISIS BB you tighten until it bottoms out. That is what I did.
There are no new unread posts for this topic. Crank Bearing Puller for SRM Campagnolo Crank
mrgray
14
1314
Tue Apr 04, 2017 9:37 am
mrgray View the latest post
There are no new unread posts for this topic. Stronglight CT2 52/36 vs Extralite MC2 52/36 - anyone comparred performance?
dereksmalls
Sat Mar 25, 2017 12:15 pm
KCookie View the latest post
There are no new unread posts for this topic. EBay CNC Crank
whydobearsxplod
26
2116
Thu Oct 12, 2017 2:43 pm
whydobearsxplod View the latest post
There are no new unread posts for this topic. 130 BCD crank w/ 52/36 chainrings?
jbaillie
9
1679
Sat Jan 28, 2017 3:35 pm
mythical View the latest post
There are no new unread posts for this topic. Crank arm size
WhyZ
Sat Feb 18, 2017 10:20 am
Kayrehn View the latest post
Users browsing this forum: faucon, Google [Bot], ipaul, saab2000, shk1, tomycs and 48 guests
cron
