Post new topic Reply to topic  [ 8 posts ]
PostPosted: Fri Mar 19, 2004 1:30 pm
 Post subject:
PostPosted: Fri Mar 19, 2004 1:36 pm
It's made diffently - as I understand it the "new" carbon as you can see on the Record cranks and is used on all Trek OCLVs, is made from a paste and then baked, this is why you get the smudgy affect.
Where as the old style of carbon is simply layered up, bit of by bit and thus looks pretty!
 Post subject:
PostPosted: Fri Mar 19, 2004 4:56 pm
The "new" carbon is unidirectional carbon fibers. It is a process that uses carbon flakes, and extremely high pressure bonding. The flakes are bonded together in random directions and create a super strong structure.
The "old" Is just woven carbon fibers. Different plys, different layers, each in a direction to strengthen the product.
MAMA SAID KNOCK YOU OUT! HUH!
 Post subject:
PostPosted: Fri Mar 19, 2004 5:19 pm
Mechanical properties should also be more consistent with the "new" since it doesn't require manual layup and avoids the consistent error generation of humans.
It's also cheaper for that reason.
 Post subject:
PostPosted: Fri Mar 19, 2004 5:38 pm
what part of OCLV? the tubes are roll wrapped uni and the lugs are bladder moulded uni
something new?
www.crumptoncycles.com
 Post subject:
PostPosted: Fri Mar 19, 2004 5:42 pm
Nick....since your a carbon builder, can you give some of us less tech informed board members a quick tutorial on differences in carbon building (OCLV, Uni, Void Compaction, glues, ect).
Thanks!!!
 Post subject:
PostPosted: Fri Mar 19, 2004 5:44 pm
It's the other way around:
The new carbon is "multi-directional", theorectically able to disperse load in all directions, while the braided carbon is "uni-directional", comprising a primary strength axis.
http://www.velonews.com/tech/report/articles/5350.0.html
Quote:
Dear Lennard;
I was reading about the new Campy carbon cranks (both Record and Chorus):
"These new products have been developed using Unidirectional Carbon Fibre, a new composite material technology that originated in the aerospace industry." For 2004, this replaces Campagnolo's previous 90-degree carbon fiber lay-up for cranksets. This new technology distributes carbon fiber in all directions to produce mechanical resistance in any direction.
Furthermore, Campagnolo's Unidirectional Carbon Fiber has been placed to further enhance the already outstanding performance of the Record and Chorus cranksets."
Is this carbon fiber that much different than the "traditional" carbon used on Giant bikes or even my Easton monkey light carbon riser bars?
I also thought about another friend who just bought a new 2004 Trek carbon bike with a "nude" finish...in other words, you see the carbon instead of paint.
The carbon on the Trek looks unidirectional like the carbon on the new Campy cranks. So....finally...the question......Is this "new" unidirectional carbon the wave of the future or just an alternative? I am thinking of buying a carbon frame this year, either Giant or Trek and I am wondering if there are advantages or tradeoffs that I am not really considering.
Mike
Answer from Trek:
We believe that Mike may have accidentally mis-worded his question. The consumer stated that the new carbon fiber (that Campagnolo is using) is a "unidirectional" carbon fiber, when in reality it is a "multidirectional" carbon fiber material (www.Campagnolo.com).
In 2000, Trek was the first company in the bike industry to introduce a frame component using multi-directional carbon fiber. This new material, called OCLV MC (Optimum Compaction Low Void Molding Compound), was used for the rocker links on the Fuel 98 and 100 suspension frames. OCLV MC is a proprietary material that uses the same carbon fiber as traditional unidirectional carbon fiber, but rather than having the fibers all oriented in one direction, it has shorter (50 mm long) randomly oriented bundles of carbon fiber. The randomly oriented fiber bundles cause this material to have nearly identical mechanical properties in all directions.
While traditional carbon fiber works well in many tubing applications
(where a high strength to weight ratio) is desirable, due to molding difficulties, it doesn't always work well for molding parts with ribs, tight radii, counter bore holes, and other complex 3D features. OCLV MC however, while still having a high strength to weight ratio, works very well for molding parts that are not hollow (like tubes) and that have complex 3D features.
At Trek, we look at OCLV MC as a material that compliments our traditional OCLV unidirectional material. It will not replace it. Both materials will always have their place in our product line-up. Regarding the question of "Trek vs. Giant", both companies have similar materials available to them so the main difference is the process used to create the bike frame. Trek uses a patented process called OCLV (Optimum Compaction Low Void) to produce our carbon frames. The OCLV process allows us to produce composite frames that are virtually free of voids (which weaken the bond) in the composite laminate and that exceed aerospace standards. We believe this process sets us apart from our competition through the high quality parts that it produces.
Brian Schumann
Trek carbon engineer
and from Campagnolo:
Quote:
Record™ Carbon Crankset
The carbon-fiber Record crankset outclasses itself.
A new technology of composite materials that was recently introduced to the aerospace industry is now used in the new Record crankset: Multidirectional Carbon Fiber. This new technology distributes the carbon fiber in all directions to produce mechanical resistance in any direction. In addition, if it is not sufficient, Unidirectional Carbon Fiber has been judiciously positioned to further enhance the already outstanding mechanical performance of the Record crankset.
The results are amazing. Last year’s Record crankset was vastly superior to those of our competitors and this new one outclasses itself:
- Innovative design for maximum stiffness
- weighs just 500 g
- greater resistance to static load
- greater resistance to fatigue
- greater resistance to torsion
The absolutely innovative result is that this new technology enables an industrial process to be created that eliminates the erratic results and performance of a manual process. Arranging the carbon fiber in the cranksets was until now an exclusively craft activity and because of this results and performance within the same component could differ widely. But by industrializing the process we have finally been able to obtain components that are all of the same impeccable quality.
The chainrings with their ultra-drive geometry have been given a special new treatment that reduces attrition with the chain and improves resistance to wear.
Another important aspect of this new carbon-fiber crankset that should be emphasized is the Q factor: it is the same as for the aluminum version.
"Gimondi è un eroe umano, che viene sconfitto ma che continua la sua corsa fino a tornare a vincere." - Enrico Ruggeri
 Post subject:
PostPosted: Fri Mar 19, 2004 6:20 pm
Thanks!!!
I can give you a quickie on the OCLV road frames.
The tubes, which include top, down, seat and both chain and seat stays as well as the single tube above the wishbone, are all unidirectional pre-impregnated carbon fiber roll rapped over steel mandrels. There is ~8 to 12 layers of varying orientation depending on the tube. These layers are tightly wrapped around the mandrels and then finally wrapped with a poly shrink tape and oven cured. After cure the mandrel is removed, tape peeled and the tubes are sanded smooth.
The lugs of the standard OCLV frame are laid up in mold halves like a clam shell. They are also multiple layers of pre-impregnated uni, in various orientations. Close the two halves together with a pressurized bladder inside, bake an viola. The lugs are finished on a CNC to machine the ends down so that the tubes will fit over them (opposite C40)
Glue lugs and tubes together in a traditional jig. Load finished product with polyester body filler and sand smooth. Requires paint or at least a light dusting to hide the body work This is why you never see a production OCLV in clear.
This is a sweet bike but so many of them out there, I’m sick of looking at them.
As for the molding compound mention of the fuel linkage parts, this is good stuff for solid parts such as linkage or a crank. This technology is called Bismaleimide Molding Compound. (BMI MC) and as far as Trek taking credit for inventing it… hmmm
Users browsing this forum: Barters, Bing [Bot], Exabot [Bot], Google [Bot], Google Adsense [Bot], HammerTime2 and 51 guests
There are no new unread posts for this topic. BTP carbon cage - carbon fiber or plastic ???
maverick_1
16
1351
Thu Feb 21, 2013 8:38 am
mann2 View the latest post
There are no new unread posts for this topic. Is it in my head or is there really that much difference?
wkend_warrior
Tue Aug 28, 2012 3:52 pm
sugarkane View the latest post
There are no new unread posts for this topic. Attachment(s) Carbon Moulds
gg333
Thu Oct 25, 2012 11:41 am
latman View the latest post
There are no new unread posts for this topic. OBE Carbon rim pads
chazzawoods
Thu Sep 06, 2012 10:51 pm
eric View the latest post
There are no new unread posts for this topic. BTP Carbon Hoods
doomith
Wed Apr 03, 2013 4:28 am
theremery View the latest post
It is currently Thu May 23, 2013 11:10 pm
