It is currently Mon Mar 27, 2017 10:07 am
Post new topic  Reply to topic  [ 22 posts ]  Go to page 1 2 Next
PostPosted: Mon Apr 24, 2006 6:11 pm
Just bought a 2006 Ghisallo titanium frame for my next WW build--shooting for 9 pounds and would like to know the best way to remove those decals!!!
thank you
:smartass: DO NOT RIDE AN AX-LIGHTNESS FORK :smartass:
 Post subject:
PostPosted: Mon Apr 24, 2006 6:19 pm
If they aren't cleared use a heat gun... or your wifes hair dryer.
PostPosted: Mon Apr 24, 2006 6:35 pm
good luck :D
21 for road 27 for mtb :D
 Post subject:
PostPosted: Mon Apr 24, 2006 6:42 pm
fingernails
PlusOneLap.com: Everything Cyclocross
 Post subject:
PostPosted: Mon Apr 24, 2006 6:47 pm
Acetone or Goo Gone with a cloth. Post pics when your done. Why do you want to remove the decals???? The new Ghisallo/Litespeed badging is sweet.
 Post subject:
PostPosted: Mon Apr 24, 2006 6:49 pm
decals are extra weight--right!!!
 Post subject:
PostPosted: Mon Apr 24, 2006 6:57 pm
Hardcore WW :D The build will lighten the wallet as well :shock: Have fun with it. What size frame? That frame looks sweet w/ WCS fork. Someone on here has a source to get them without the Ritchey decals. VERY STEALTH and when cut should come under 300 grams.
 Post subject:
PostPosted: Mon Apr 24, 2006 7:45 pm
NO WAY!! The Ritchey fork is TOOOOOOOO Heavy for this type of build. Ordered a THM Scalpula SP tuned from Mdacow and a few other very extra light carbon goodies. The fork should be 240-220 grams cut. The frame is a medium and weighs in at 772 grams!!! (this is completley stripped--no bb cable guide or bolt, no shifter adjusters, no FD clamp or bolts, no seatpost clamp or bolt, no RD removable dropout hanger.
with the RD dropout hanger it weighs in at 780 grams
replacing:
bb guide to carbon and no bolt--just a dab of tire glue (2 grams)
shifter adjusters will be BTP carbon ??? grams
FD clamp will be BTP carbon (special made) ???grams
seatpost clamp already have --BTP carbon 8 grams
 Post subject:
PostPosted: Mon Apr 24, 2006 9:50 pm
I've done many times on my Litespeed's. Use PURE acetone and a cloth. Dab it on the decal, let it work or penetrate for about 30 seconds and start rubbing slowly. when you think your done, get a clean section of the towel, more acetone or citrus cleaner and wipe one last time. Good luck
 Post subject:
PostPosted: Mon Apr 24, 2006 10:53 pm
When I worked there I weighed a sheet of decals before they were put on the frame and they were only 10 grams and that included the paper that they were on. So stripping the frame will only save you about 4 to 5 grams total but if you want to remove them acetone and a rag and they will wipe right off.
 Post subject:
PostPosted: Mon Apr 24, 2006 10:58 pm
Use your finger nails to scrape them off then use WD-40 to remove the glue. Works like a champ and doesn't smell as bad as acetone.
Tim
 Post subject:
PostPosted: Tue Apr 25, 2006 6:36 pm
thanks everone--Ihave no fingernails and not even a hair dryer so I chose the acetone route and it was pretty fast (5-10minutes) and no mess. The frame is now 4 grams less--that is what matters :)
thanks again :D
 Post subject:
PostPosted: Tue Apr 25, 2006 8:19 pm
nutter :lol:
 Post subject:
PostPosted: Tue Apr 25, 2006 10:53 pm
Resident Pro
9 lbs! wow great. i recommend using a good headset though.....the plastic ones in my experience have not worked well (m2racer)....u may also want to ask pkor what he thinks of his plastic headset. he may have different opinion.
 Post subject:
PostPosted: Wed Apr 26, 2006 1:03 am
9 pounds...thats insane. I'm limited to 14.96lbs(6.8kg)...stupid UCI!
www.ChrisDiRe.com
Adam Hansen wrote:
Sponsors should not have to go, its the doped riders that should be shot instead, in the knee caps would be nice.
 Post subject:
There are no new unread posts for this topic. Custom Frame Decals
SpecializedColnago
Fri Mar 03, 2017 9:49 pm
duvivr6 View the latest post
There are no new unread posts for this topic. Cannondale Frame Stickers/Decals
Valbrona
Mon Aug 08, 2016 7:12 pm
caad10dotcom View the latest post
There are no new unread posts for this topic. Best Way to Remove Oxidation from Spoke Nipples
ipenguinking
Mon Oct 17, 2016 2:53 am
TheKaiser View the latest post
There are no new unread posts for this topic. How to remove logos on Hylix carbon seatpost
stripes
Sat Mar 04, 2017 3:14 pm
evan326 View the latest post
There are no new unread posts for this topic. How to remove Reynolds freehub Strike SLG wheelset?
poppiholla
Fri Jan 20, 2017 11:52 am
poppiholla View the latest post
Users browsing this forum: beanbiken, burglarboycie, corky, cyclespeed, Google [Bot], petromyzon, Yahoo [Bot], zirxo and 16 guests
