Arrrrrrh!
LBS mechanic just called and Fyberlites won't work with the Clavicula SE/e-Tap as it's about 0.7mm off.
This is my WW build and now it looks like it may not happen.
Should I go Carbon-Ti or Rotor Qarbon in a compact/sub-compact? This is my last bike.
2015 Pinarello F8: 13.13lbs/5.915kg(w/Roval 64's). Sold.
2016 Rca: 11.07lbs/5.048kg.
2015 Rca. 11.15 lbs(w/Roval CLX 32's)
2015 Rca/NOS(sold).
2018 S-Works SL6 Ultralight 12.03lbs(w/Roval CLX 50's)
2015 Rca/NOS(sold).
Go get you some Praxis .. the shift really well
2024 BMC TeamMachine R Building
2018 BMC TImeMachine Road
2002 Moots Compact-SL- getting aero look makeover
2023 Pivot E-Vault - completed project, full Xplr package
The heavy stuff? Hard Pass. Just ordered Carbon-Ti from FWB.
2015 Rca/NOS(sold).
2015 Rca/NOS(sold).
Well THM BB is not exactly light atleast mine is not... this is for your RCA so maybe you get lucky. You can do extralite and that would still shift better then Carbon-Ti
Part of the reason for getting fiberlyte is in the looks, and carbon-ti can look the part as well, so I think it's a good match. I'm going to try their carbocam rings real soon actually, with an electronic groupset hopefully shifting wouldn't be a problem.
Good point there about the BB weight - with that included the THM cranks doesn't save much weight at all over the Sram red BB30 cranks.spdntrxi wrote:Well THM BB is not exactly light atleast mine is not... this is for your RCA so maybe you get lucky. You can do extralite and that would still shift better then Carbon-Ti
Oy!,Kayrehn wrote: ↑Fri Mar 23, 2018 3:29 amGood point there about the BB weight - with that included the THM cranks doesn't save much weight at all over the Sram red BB30 cranks.spdntrxi wrote:Well THM BB is not exactly light atleast mine is not... this is for your RCA so maybe you get lucky. You can do extralite and that would still shift better then Carbon-Ti
Why didn't you say that before?
2015 Rca/NOS(sold).
2015 Rca/NOS(sold).
Going to call FWB tomorrow to see if I can change my order to the X-Carbo's.Kayrehn wrote: ↑Fri Mar 23, 2018 3:20 amPart of the reason for getting fiberlyte is in the looks, and carbon-ti can look the part as well, so I think it's a good match. I'm going to try their carbocam rings real soon actually, with an electronic groupset hopefully shifting wouldn't be a problem.
Thanks.
2015 Rca/NOS(sold).
2015 Rca/NOS(sold).
Carbon-ti chain rings shift ok. Not bad, just ok (they are not DA or Paraxis, that is.) But they look nice, I'll tell ya...
I first put them on an etap setup, then switched them to 9150. Di2 works better with them (I think it because of the di2's faster shifts...)
I think the THM BB is lighter for an RCA then the one used for my Parlee , how much I dont know. But yes comparing Red Cranks+rings+BB to THM cranks+BB+Praxis rings.... really not a huge weight savings for the $$$$. Somewhere in another thread I posted the difference ?tabl10s wrote: ↑Fri Mar 23, 2018 4:20 amOy!,Kayrehn wrote: ↑Fri Mar 23, 2018 3:29 amGood point there about the BB weight - with that included the THM cranks doesn't save much weight at all over the Sram red BB30 cranks.spdntrxi wrote:Well THM BB is not exactly light atleast mine is not... this is for your RCA so maybe you get lucky. You can do extralite and that would still shift better then Carbon-Ti
