Campagnolo Jockey wheel ceramic bearing replacement
c60rider
by c60rider
Decided to pull the jockey wheel apart to clean and also picked the seals off to fully clean out the bearings. Shaking the excess water out after I'd cleaned it all and the whole inside of the jockey wheel fell out and all the bearings magically disappeared! :noidea: I suspect that all of them somehow slipped in between the decking area I shook it on. So rather than me fork out the near £50 for replacement jockey wheels does anyone know the size of bearing that goes in there??? The numbers on the seal of the bearing come up with nothing at all and searching specifically for the bearing size gives me nothing.
AJS914
by AJS914
FWIW, you can buy Tacx wheels with ceramic bearings for around $25.
Miller
by Miller
There are bearings in Campag jockey wheels? All I've ever seen in there is a brass bushing.
c60rider
by c60rider
Miller wrote:
Sat Mar 10, 2018 8:48 pm
That's all the cheap ones have in them, the record/super record have ceramic ball bearings in the bottom jockey wheel, top one is the standard brass bushing
reknop
by reknop
AJS914 wrote:FWIW, you can buy Tacx wheels with ceramic bearings for around $25.
Also C-Bear probably has some since they are sponsoring the Lotto Soudal team, who are riding Campagnolo
Sent from my Redmi Note 3 using Tapatalk
https://www.remo-knops.com/cycling/
Butcher
by Butcher
One of my SR derailers has a ceramic bushing and a ceramic bearing. I believe the lower one has the bearing.
c60rider
by c60rider
Managed to answer my own question :smartass: the diameter of these bearings is 2mm should anyone do the same idiotic job of losing them. Replacements only seem available from the far east via eBay but just £4.57 for a pack of 20 somewhat better than buying a new set of jockey wheels. Just got to wait ages for delivery :roll:
Zakalwe
by Zakalwe
Simplybearings.co.uk should have 2mm available
c60rider
by c60rider
Zakalwe wrote:
Sun Mar 11, 2018 5:47 pm
Not the ceramic ones used here in fact very few people seem to sell them
PinaRene
by PinaRene
reknop wrote:
Sat Mar 10, 2018 10:24 pm
Correct - I have them in use, great jockey wheels.
reknop
by reknop
PinaRene wrote:
Sun Mar 11, 2018 7:08 pm
I don't have the jockey wheels, but I'm very pleased with the C-Bear ceramic bottom bracket. :) It is a rock solid vendor to go with ...
guyc
by guyc
reknop wrote:
Wed Mar 21, 2018 2:19 pm
Good to know as I've just had one fitted to a new build....
