Best grease/lube for DT Swiss ratchet system
Greenduck
by Greenduck
Hi all,
I just received a pair of DT Swiss PRC 1400 wheels which uses 240s hubs and their rachet system. I read different places that the red grease from DT Swiss causes quite a bit of drag. Also when I turn the cranks backwards it feels like theres alot of resistance or drag? Don't know if that's just a part of the rachet system?
Does anyone have any experience using a different grease or even a lube for even smoother operation? I'm very good at maintaining my bike components so I have no problem cleaning at re-greasing/lubing the rachet system often. So I was thinking about just using a high quality lube. Anyone with any experience to share?
Thanks in advance,
Jake
Pinarello Dogma 65.1 Think 2: viewtopic.php?f=10&t=139324
sungod
by sungod
the dt swiss special grease does not cause a lot of drag
it's thinner than typical greases used on a bike, and it should be applied sparingly - recipe is apparently 95% molykote tp-42 and 5% mineral oil - it's supplied in a tiny pot, but if you are applying it right that should last ages, i reckon 10+ years
if there's significant drag it's because too much was applied!
you could use a heavy oil, but i think you'll need to re-apply often otherwise the dry ratchets will wear fast
edit: when they're new, there's often a bit too much grease and the ratchets are pretty quiet, once it gets squished out they will get louder, when they get really loud you know it's time for a bit of grease!
ms6073
by ms6073
I will probably get roasted for saying this, but once a month or so (more frequently if we get caught in the rain), I typically pull the freehub out slightly and squirt in some Prolink Gold.
TobinHatesYou
by TobinHatesYou
White Industries recommends heavy oil or dry lube on its freehub mechanisms, but DT and CK style freehubs generally take light grease. Slick Honey is pretty light. CycleOps uses Krytox GPL226, but it’s quite expensive...
kode54
by kode54
i use NFS synthetic grease. i suppose you can use Mobil 1 grease or other similar types. never had any issues with NFS. i use it with DT 240 hubs all the time.
- AX Lightness Vial EVO D + DA9150 + Enve SES 3.4 carbon hubs
- Parlee ESX + DA9150 + THM SRM PM + Enve SES 6.7 CK hubs
- Independent Fabrication Ti FLW + DA9100 + Enve 3.4 CK hubs
GothicCastle
by GothicCastle
Greenduck wrote:
Fri Mar 09, 2018 8:10 pm
I don’t believe you did. Unless “places” were Internet forums where uninformed randos spout off with no basis in reality.
I can’t think of any case where freehub grease would cause significant drag. Bearing seals are almost certainly generating far more drag, and even that is insignificant in the context of a moving bicycle.
Catagory6
by Catagory6
I just did a complete overhaul of a 240 that was maybe 15 years old. Stripped completely apart. Cleaned re-packed bearings. Everything.
I had the same problem you describe. Lots of drag on the hub when freewheeling.
Always been that way, even when i sent the hub to a wheel builder to have a different rim built up. He said thats just the waythey are.
After the overhaul, it now spins SO much easier.
I just used a very light coating of progold epx.
I have no clueif this made the difference or not. It was just what i had laying around.
Of course i havent ridden the wheel yet (winter in new england), so maybe it will explode like fukushima under my butt
Priit
by Priit
I've used in ratchets Dupont Krytox GPL 205 - works well but it's a overkill for sure :D Krytox is very expensive and long lasting, used mostly in applications like sealed-for-life bearings and extend relubrication intervals in bearings that require relubrication. But for bottom brackets and repacking bearings Krytox (like GPL 205 or GPL 226) is quite superb.
bm0p700f
by bm0p700f
Rock n roll super Web grease or there super slick grease for lower drag.
Greenduck
by Greenduck
Thanks for all the replies.
I took of the cassette body and the rachets were smothered in grease. I have wiped most of it off and only left a very thin application. I will look into a more light lube or oil to use.
nickf
by nickf
I always use dt red grease. A thin coat goes a long way, no way it causes noticable drag. Don't like drag then keep pedaling.
Calnago
by Calnago
I have some of that “special” DT red grease for their star ratchets that came with their hub service toolkit. I always wondered what was so “special” about it.
sungod
by sungod
Greenduck wrote:
Sun Mar 11, 2018 6:06 pm
like i said, when they're new, there's often excess grease
you can put some lighter lube on, but why?
apply rational thinking and physics...
any likely loss from grease on the ratchets, or from wheel bearing grease, or seals, when coasting at speed, will be dwarfed by even minor changes in rider position, or a slightly loose jersey sleeve, or a baggy mitt, to say nothing of the drag from the spokes
spinning a wheel with the bike on a stand will be a system mass probably < 1kg, sure grease may spin down faster than oil, big deal, because that's the wrong test, the mass of bike+rider is what counts, the % impact of any drag from grease reduces in direct proportion to the ratio of the masses, and that's before the impact of aerodynamic drag out on the road
whatever you see with a wheel on a stand includes the effect of the bearing grease, and seals, and spokes etc., if you are worried about freehub drag then why not worry about the bearing grease and the seals?
try https://www.cyclingpowerlab.com/PowerSp ... arios.aspx and see what difference a watt or two makes on a descent, the exponential power impact of aerodynamic drag reduces any conceivable ratchet drag to utter insignificance
unless someone can measure a significant speed difference coasting, it's just irrelevant
wheelbuilder
by wheelbuilder
King ring drive lube.
ms6073
by ms6073
Calnago wrote:
Sun Mar 11, 2018 8:24 pm
I have some of that “special” DT red grease... I always wondered what was so “special” about it.
You mean besides it being red? I always thought attaching the word 'Red' to a product name was somewhat akin to having an amplifier that goes to 11? :beerchug:
