Cleaning gum wall tires (specifically Compass)
mattyNor
by mattyNor
So this is admittedly extremely silly and probably fairly pointless but ignoring all that.... I put a pair of gumwall Compass tires, extralite cassing, on my bad weather bike but after using them through the winter the mixture of salt, dirt, and whatever else has left them kinda more grosswall than gumwall. Is there any easy way to clean them and get them back to the original colour?
Sent from my SM-G930W8 using Tapatalk
Shrike
by Shrike
I was recommended WD40 here before. Didn't get round to trying it though. Maybe I'll try it tonight now you've put it back into my head :P
Broady
by Broady
This is my main reason for getting discs.
mattr
by mattr
I just used hot soapy water and elbow grease.
Added bonus is that the rims were also spotless.
Ltyarbro42
by Ltyarbro42
Bleche-white
kidrob
by kidrob
Broady wrote:
Wed Mar 07, 2018 1:53 pm
I really don't see the connection between dirty gumwalls and brakes.
As for cleaning the gum walls: viewtopic.php?p=1350908#p1350908
hmai18
by hmai18
kidrob wrote:
Wed Mar 07, 2018 4:30 pm
On a rim brake bike, residue from the pads mixed with whatever crud is accumulated from the road surface will end up on the sidewalls. This is less of an issue with disc-braked bikes.
Zakalwe
by Zakalwe
Shrike wrote:
Wed Mar 07, 2018 1:36 pm
Do you really want to be putting WD40 on your tyres?
Broady
by Broady
Brake pad dust mixed with rain completely blackens gum / tan sidewalls.
Shrike
by Shrike
Zakalwe wrote:
Wed Mar 07, 2018 8:54 pm
Maybe, maybe not. If you've done any research into this you'll find there's no definitive answer.
Go-karters used to use it on their tyres for grip until the practise was banned. You can see results showing magazine recommendations and rumours about the army using it for tyres too.
It's not a lubricant and shouldn't be absorbed by the tyre compound, so as long as it's not on your brakes then it'd be worth testing. You wouldn't be spraying it all over the place like a mad pirate anyway, you'd be spraying on a cloth and treating the sidewall area of the tyre. Preferably dismounted from the wheel.
Didn't get a chance last night, too tired, but after reading more about it I'm curious about how it affects grip as well as how well it can actually move difficult oil stains. If i have a go I'll post before and after pics and maybe even rub the rear tyre down and take it for a spin around the block to test grip. This weekend or next.
Broady
by Broady
I once put a Vittoria Corsa in the dishwasher, came out nearly whitewall as opposed to gum.
Marin
by Marin
Dishwasher? Cool idea. I actually bake my Veloflexes in the oven before installing so speed up the ageing. Anyone got more kitchen ideas? ;)
