Mileage Specialized Turbo Cotton?
TonyM
by TonyM
Hi,
How is your mileage for your Specialized Turbo Cotton clincher tires?
(I am using Veloflex Corsa and Vittoria Open Corsa and I am thinking about trying the Spec. turbo cotton)
spdntrxi
by spdntrxi
I've got nearly 3k miles off of them... the rear is looking a bit squared off.
TonyM
by TonyM
spdntrxi wrote:
Mon Mar 05, 2018 11:16 pm
Sounds good :thumbup:
Which size are you using and how much psi do you put in ?
(I am wondering that for the 24C it should be at least 115 psi based on the information on the their website "700 x 24mm, PSI 115-125").
spdntrxi
by spdntrxi
24C.. but I never used more then 100-105psi. To be honest I never even looked at their recommendation on the website.
I'm on 24C front 26C rear now.
dim
by dim
I have the Turbo Cottons in 24c ... and they now need replacing
brilliant tyres .... at approx 900 Km, I swopped the tyres (back tyre to the front)
at 1861 Km, I got my 2nd puncture on the rear within 1 week, and decided to retire them (I used them throughout winter (approx 35-40km/day, 6 days a week for commuting on shitty roads.... in the dry and very wet)
The Turbo Cottons are the best tyres that I have ever used, and I will buy another pair for my 'fast bike' and use latex tubes.
So, in a nutshell, I would say that they are good for 2000 Km, before they start wearing thin .... I weigh 75 Kg if that helps
On Conti GP4000, I start getting punctures on a regular basis once the rear tyre has approx 2600 Km
Giant TCR
Canyon Endurace AL
Whyte Suffolk Gravel Bike
spdntrxi
by spdntrxi
I must be easy on tires.. and I'm 82kg... I have not recycled my old rear yet.. if I can find it, I'll take a pic of the tread. For me they wear the same as GP4000s if not better. I seem to square those off really quickly. No flats for me, but I did have a bunch of cuts that I filled in with krazy glue.
mrlobber
by mrlobber
3 tyres, average mileage 2200km. All retired after torn sidewalls, one was rendered completely unusable, two others - suspicious enough for me not to ride them anymore.
That said, I did at least one gravel race with a pair of them, which might have contributed to the sidewall damage.
CrankAddictsRich
by CrankAddictsRich
mrlobber wrote:
Tue Mar 06, 2018 7:56 am
Yea... they are NOT a tire for gravel rides.
2016 Pactimo Brand Ambassador
http://www.Crankaddicts.cc
http://www.skratchlabs.com
2015 Specialized S-Works Allez
2015 Specialized Venge Pro
2014 Specialized S-Works Shiv TT
cassard
by cassard
turbo cotton's as durable as 4000s II ? I don't believe that
mattsurf
by mattsurf
I have a set of Turbo Cotton Hell Of The North 28mm tyres (designed for Paris Roubaix), that I got direct from Specialized. I just checked, and have done 6007km on them, I have had one puncture, and they still have loads of life in them. Admittedly I did move to Switzerland in September, so 2500km or so are on nice smooth Swiss roads, however the rest of the mileage is mainly rough/potholled Witshire roads
I had a set of GP4000II prior to these tyres, and had more punctures in less miles, also prefer the feel of Turbo Cottons, and they are as quick/faster than the Continentals
spdntrxi
by spdntrxi
cassard wrote:
Tue Mar 06, 2018 9:28 pm
believe it... I ride some crap NorCal roads and used TCs in the winter.. so all kinds of debris.
nickstea
by nickstea
mattsurf wrote:
Tue Mar 06, 2018 10:46 pm
I haven’t seen these 28s... are they clinchers?
mattsurf
by mattsurf
Yes they are Clinchers, i bought them in the US. I heard that they are not available in Europe, which is a shame as they are the best tyres I have owned
petromyzon
by petromyzon
spdntrxi wrote:
Tue Mar 06, 2018 11:07 pm
I'm sorry this is just nonsense. Unless you have a large group of riders doing a controlled experiment and putting tens of thousands of kms on them you can't prove this .
Sometimes you just have to look and feel a tyre and make an assumption about the relative durability.
The rubber on TCs is much thinner and the sidewalls more exposed. They have a traditional rather than fully vulcanised construction.
I ride TCs but in the expectation that cost per mile will be 3-4x greater than GP4000 because they both cost more and will last poorly.
I do it because life is short and bike rides are precious; they feel better and roll better.
Marin
by Marin
mattsurf wrote:
Wed Mar 07, 2018 9:30 am
No, you can buy them in Europe: https://www.bike24.de/1.php?content=8;p ... 00,4,22,35
BTW my Turbo Cottons have been as durable as any similar tire, and I've ridden them on gravel too.
