Can Di2 wireless unit be placed inside the frame?
vinuneuro
by vinuneuro
I normally see it external. Maybe it can go next to junction box B in the downtube or in the seatube?
2016 Diverge Expert
IrrelevantD
by IrrelevantD
vinuneuro wrote:
Thu Feb 01, 2018 5:53 pm
YES. I have hidden the wireless inside the down tube on both a carbon and an aluminum frame and have had no issues with connectivity to my Garmin via ANT+, nor to my iphone via BT.
madcow
by madcow
We do it regularly, along with putting the a junction inside the seatpost with the battery, if you have the right stem you can make an almost completely hidden system without needing any internal routing on the bars and stem. Here's a moots ti frame where we put the transmitter inside and it works just fine you can see in the pictures most wires are able to be completely hidden. http://blog.fairwheelbikes.com/2017/12/ ... -di2-disc/
TonyM
by TonyM
Yepp in the frame ok - except if you have a steel frame as stated from Shimano.
Stueys
by Stueys
Interesting. I guess the main downside is you can't index the gears on the fly? Otherwise it's a good idea
spdntrxi
by spdntrxi
Yes.. I had mine in the seat tube with the battery (parlee z5i)
2024 BMC TeamMachine R
2018 BMC TImeMachine Road
2002 Moots Compact-SL
2023 Pivot E-Vault
rsantos450
by rsantos450
Mine is inside the SL6, works fine.
kode54
by kode54
madcow wrote:
Thu Feb 01, 2018 6:14 pm
madcow, it says on your link that you have another A junction that you use to charge with. is it possible to connect 2 A junctions to do this? sounds like a great way to hide the A junction which i hardly use. only to charge and after initial adjustments.
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
bikehaus
by bikehaus
How does the wireless unit and battery get wired and fit around the seatpost area? I have a Ti frame and am consideing this.
2old4this
by 2old4this
bikehaus wrote:
Tue Jul 24, 2018 7:54 am
Assuming your frame can be wired internally, you can put your battery inside the seat tube and secure it with something like this
https://www.amazon.com/Ritchey-Seatpost ... dpSrc=srch
Then all you have to do is to connect your wireless unit to the battery with a short di2 wire (10 cm?) and the other end of the wireless unit to the rest of the system...
bikehaus
by bikehaus
I should have been more clear - can the wireless unit transmit through titanium downtube? I heard it cannot through steel and I am not smart about these materials. If not, I was then wondering then how you squeeze a battery and unit all within the seatpost area, in my case an aluminium one - and not the downtube area.
2old4this
by 2old4this
bikehaus wrote:
Tue Jul 24, 2018 8:05 pm
I guess it all depends. I had to move the wireless unit from seattube to bottom bracket to way up in the downtube. Finally, took the unit out and tied it under the JuncA on the stem (this is a carbon Storck frame. :noidea: )
Then again, if you want hidden, if all fails, you can place the wireless unit inside the handlebar...
Robbie84
by Robbie84
I have placed mine in the left bar end connected to the left shifter (only one end of the wireless unit needs to be plugged in). I have the Pro Vibe Aero carbon bars that are designed for internal wiring, and the bar-end junction box in the right side. One Di2 wire is then heat-shrunk to the rear hydro hose to the b junction at the bb.
