Di2 wire lengths
vinuneuro
by vinuneuro
Could someone kindly confirm if the wire lengths I have are correct? This is from a Specialized rep but they are not matching up with what I've found online. For a 56cm frame 2016 Diverge which is near identical dimensionally to the Roubaix.
Downtube 1000mm etube (seems 50mm long?)
FD - 500mm (seems 100mm long?)
Shifters 2x 350
RD 700 or 750 (seems 100-150mm long?)
Battery to Juction B 1000mm (?)
'16 Spec Diverge Expert
kode54
by kode54
depends if you decide to incorporate the handle bar end junction. if that's the case, you'll need a longer wire from junction B to shifter or bar end junction.
what junction do you plan to use? A or the handle bar end one?
- AX Lightness Vial EVO D + DA9150 + Enve SES 3.4 carbon hubs
- Parlee ESX + DA9150 + THM SRM PM + Enve SES 6.7 CK hubs
- Independent Fabrication Ti FLW + DA9100 + Enve 3.4 CK hubs
vinuneuro
by vinuneuro
Probably A. I already have a carbon bar and don't want to buy another one just for this.
IrrelevantD
by IrrelevantD
If it’s cabled internal, I prefer to go a little long. Not like a couple hundred mm is going to hurt you that much in weight, and any slack is hidden inside the frame.
Rob1519
by Rob1519
The reps recommendations are fine. No penalty to being a little long but too short is a pain. If bars are wider than 44, you may want to increase the A to shifter lengths.
Cemicar
by Cemicar
If your concern about longer wires is those weights, never mind them. Those cables only add less than 1 gram per 100mm. Rather, care about the case where any of your cables is too short. It costs $30 or so.
vinuneuro
by vinuneuro
My concern is extra wire length rattling inside.
Rob1519
by Rob1519
vinuneuro wrote:
Wed Jan 24, 2018 4:41 pm
If there is cable rattle, Shimano produces a cable (SD-501) tie that attaches to the wire and lightly presses against the inner wall of the bike tubing.
The only rattling I ever had was from an internal B junction. Solved with a little foam.
kode54
by kode54
before Shimano made the reusable cable ties, regular cable ties were recommended, leaving the tail on it instead of trimming it like usual. the reusable ones are nice since you can move them around the length of the wire.
too short wire may disconnect from ports when stressed. better to have slack to take up some of the pull when turning handlebars, etc.
IrrelevantD
by IrrelevantD
as others have mentioned, just get a handful of small zip ties slightly longer than the diameter of the tube. They're cheap, space them out a few inches a part and they'll pretty much hold the cables in place inside the tube and keep them from rattling. I'm even using that technique to keep my Bluetooth/ANT+ unit in place inside the frame. Works like a champ.
