new 2018 Hollowgram SISL2
eliflap-scalpel
by eliflap-scalpel
i had it replaced for a crack close to bolt hole
left arm only, 2018 version
10 g heavier
Cannondale has slightly revised machining near the fixing bolt
http://eliflap.it/
eliflap-scalpel
by eliflap-scalpel
new 'Pedal washer required' mention
http://eliflap.it/
eliflap-scalpel
by eliflap-scalpel
new graphic
http://eliflap.it/
eliflap-scalpel
by eliflap-scalpel
same lenght, 170mm
old version and graphic
http://eliflap.it/
parleez1
by parleez1
eliflap-scalpel wrote:
Wed Jan 17, 2018 9:32 pm
10 g heavier
I'm looking to replace my Hollowgram SiSl2 172.5mm crank arms with 165mm arms, do you know if the 2018 arms will fit a 2014 model?
Thanks!
eliflap-scalpel
by eliflap-scalpel
yes, seems to be same as older versions
http://eliflap.it/
