Chainrings for first gen Sram Red
Mr.Gib
by Mr.Gib
Mrs. Gib's travel bike has an original 5 arm Sram Red crank and before I replace the stock rings with more of the same or perhaps Praxisworks, I was curious if anyone had a better alternative. My main complaint is that with the stock rings the chain catches the teeth of the big ring when in the small/small combo. I also get contact when in the second cog and even a bit in the third cog It would be nice if the replacement rings performed like Red 22 rings which run clean in any combination. The problem is IIRC Red 22 rings won't work with the old style crank.
I have Praxisworks rings on another bike and while they are good overall, they are still not great in small/small. The Praxis I have are a few years old - have they improved? The other thing about Paxis is that they want you to use any chain but Sram. Unfortunately the cassette is Sram and works best with Sram chains. Anybody get good results with Praxisworks and Sram chains?
Other suggestions?
glepore
by glepore
Red 22 rings will work on the old style crank, they now come with the chain drop pin for either position.
Cysco Ti custom Campy SR mechanical (6.9);Cannondale SS Evo Di2 7970 (5.79); Willier Cento Uno Air Di2 9070 (7.0); C40 Mk2 DA 7800 ; Anvil Custom steel Etap;1996 Colnago Technos Record
sungod
by sungod
you'd need to measure positions and do the trigonometry, but it may be inevitable that the chain rubs in such a situation - i've got sram and shimano both would rub if i cross chained that way
Mr.Gib
by Mr.Gib
glepore wrote:
Tue Jan 16, 2018 7:23 pm
Thanks, I remember now. The un-needed pin comes out and they give you a little rubber grommet to fill the hole. My memory is clearly failing. :?
sungod wrote:
Tue Jan 16, 2018 8:45 pm
Even with Sram 11 speed? I have Red 22 on a few bikes as well as second generation 10 speed on others running on Exogram cranks and in all cases small/small runs perfectly clear or nearly so even on bikes with short chainstays, and even on my cross bike with the wider rear end. Shimano not so much. Perhaps some bike designs just ask for too much angle.
Calnago
by Calnago
Also, a 34/50 compact crank (not sure what’s on your wife’s bike) will be more likely to exhibit that behaviorl because the difference between the two diameters of the rings is greater than it is on say, a standard 39/53 setup.
Mr.Gib
by Mr.Gib
Indeed, the 16 tooth difference increases the problem on all bikes relative to the standard 39-53. Nice thing about Sram 22 is that the chain runs clear even with the 34-50 crankset. Comes down to well designed rings.
