Differences between TCR advanced and TCR advanced pro
In Australia, the 2018 TCR Advanced Pro 1 with Ultegra in Large weighs 7.45kg stock, without pedals or bottle cage, but with a bell, and reflectors on both wheels, and front and back (required by law).
Advanced Pro 0 with Dura Ace and slightly better wheels weighs 7.0kg, without pedals or bottle cage, but with reflectors and bell.
Those carbon wheels are amazing.
I saw the weight of the fork on a post here on weightweenies and recall thinking that it was pretty light for a fork with an alloy steerer. It's definitely not >550 grams. I'll try find the post.
edit: I don't think this is the one where I originally saw the weight, but it is listed here (viewtopic.php?f=10&t=146903) as 470 grams. It looks like there is still a fair amount of steerer still on it too.
Thank you for the link saying hybrid fork is 70 gr heavier. Actually the points that I care on a bike are Rigidity, responsiveness, beauty, quality, the most importantly sizing and geometry, I sold my old bike being ideal in size only because of this reason. I am not definitely a weightweenie (it is ok to race with 2 kg wheelset Now you can hang me.LM7805 wrote: ↑Fri Feb 16, 2018 4:55 amI saw the weight of the fork on a post here on weightweenies and recall thinking that it was pretty light for a fork with an alloy steerer. It's definitely not >550 grams. I'll try find the post.
Btw I m looking forward to meet my new Tcr Advanced frame set. I will post its specifications here
Update: I have finally handed on my Tcr Advanced 2017 frameset. Weight of the parts is below:
I am surprised that frame is lighter than I thought.
Small size frame (without anything, only including front mech and rear mech hangers and all inner cable route exit blocks: 867 gr)
Hybrid OD Fork: 475 gr (with only star nut being inside the shaft)
Headset (including spacers, caps, screw, bearings): 98 gr
Seatpost (will come):...
If u one day got bored of it u could just swap the fork with this:Cyclist999 wrote: ↑Thu Mar 08, 2018 1:44 amUpdate: I have finally handed on my Tcr Advanced 2017 frameset. Weight of the parts is below:
Small size frame (without anything, include only front mech frame hanger): 867 gr
https://shop.vannicholas.com/en/product ... 9#MVVN0220
Van Nicholas VNT SLR Full Carbon fork. It's the same rake.
Thanks for the recommendation, I will think it to buy, if anything goes wrong with the original one, but I hope it wontMagicShite wrote: ↑Thu Mar 15, 2018 1:19 pmIf u one day got bored of it u could just swap the fork with this:Cyclist999 wrote: ↑Thu Mar 08, 2018 1:44 amUpdate: I have finally handed on my Tcr Advanced 2017 frameset. Weight of the parts is below:
Bit of a thread revival but here goes
Eventually got around to weighing the 2017 TCR Advanced alloy steerer fork, inc crown race and starnut which will be circa 15-20g
In the meantime I picked up an SL fork, didn't get a pic but it came in at 339g, white so I've stripped it here's 1/2 way through (328g)
Then stripped. Just needs finishing, a run over with some fine sandpaper, waxed and the steerer cut down around 15mm
No need to sorry, thank youdefride wrote: ↑Thu Feb 15, 2018 6:07 pmSorry, my mistake that should be frameset at around 1400g. And the fork, seen plenty alloy steerer forks at +500g, heavy! When I drop mine out to cut the steerer I'll get an accurate weight and post a pic.Cyclist999 wrote: ↑Thu Feb 15, 2018 3:10 pmThanks.
The main problem here that I do definitely give no chance that frame is 1400 gr, it is just impossible. It is sub 1 kg frame for sure. Therefore that mate's assumption is most probably wrong: it can not be only bold frame. 400 gr for fork is ok without cut. Tcr aluxx sl overdrive 2 fork comes in 388 gr.
Thanks for sharing. Exactly same fork with my tcr 2017 adv 1 kom edition. Since the only requirements for mounting SL or Pro fork in TCR Advanced frame, are overdrive 2 headset, expander and 31.8 stem. I am doing same if the Adv SL fork that I have purchased came without accident. I might share it in a month.defride wrote: ↑Wed Oct 03, 2018 2:16 pmBit of a thread revival but here goes
