Quarq DZero Spider Sram Rotor compatibility
by Jian81
Hi guys im thinking of getting my first ever Quarq powermeter. However, im plagued with concerns on compatibility. I currently have a Quarq Ready Sram Red 22 BB30/BB386 crankset with the modular crank arm system. It uses a Hidden Bolt design.
My question is can i use the same crank arm on a NON-hidden bolt Quarq power spider? The SRAM chainrings will be swapped out for Rotor NoQ Carbon rings. Both are 110BCD so no issue there.
Any help would be greatly appreciated, thanks!
by dre_lo82
It sounds like you've got the "Prime" crankset they offer with some of the OE builds. The answer is yes, you can use it with the hidden and non-hidden though when you order your spider from Quarq, you have to specify whether you want the hidden or non-hidden version.
