help installing sram red 22 crank (PF30 with bb30 spindle)
Allen254
by Allen254
Im trying to install sram's red 22 crank but Im a little confused I have a Fuji sl with a PF30 so I bought kogel's pf30 BB that fits sram bb30 spindle.
According to sram I don't need any spacers only the preload, but im having a hard time understanding the preload and how it works I have like 0.5mm side play. What am I doing wrong.
BikeKingV1r
by BikeKingV1r
Should be a small Allen screw, simply loosen it and rotate the preload until the slop is gone and tighten the screw. Check and do it again if needed either too tight or loose still. I did a quick search on YouTube and here’s a link https://youtu.be/IINjQKK7INI
lyrictenor1
by lyrictenor1
Allen254 wrote:Im trying to install sram's red 22 crank but Im a little confused I have a Fuji sl with a PF30 so I bought kogel's pf30 BB that fits sram bb30 spindle.
It wasn't clear from what you wrote: Are you installing a Red22 BB30 crank or a Red22 GXP crank?
Allen254
by Allen254
yeah iam installing a sram bb30 crank (on a pf 30 frame)
Allen254
by Allen254
BikeKingV1r wrote:Should be a small Allen screw, simply loosen it and rotate the preload until the slop is gone and tighten the screw. Check and do it again if needed either too tight or loose still. I did a quick search on YouTube and here’s a link https://youtu.be/IINjQKK7INI
yeah tried but it looks like the preload is touching/rubbing on the the BB lip. Is the crank supposed to have some kind of spacer. also do you know if the none drive side arm has a cap to fill the hole like on Shimano.
dvq
by dvq
On an integrated spider there should be no spacers, on a removable arm for the spider there should be some configuration of spacers -- that's not likely what you have. When you rotate your adjuster towards the "+" side, a threaded plastic lip should start screwing out towards the bottom bracket. It's easy to see here:
If for some reason you have the preload adjuster on backwards or if you're rotating it in the wrong direction it could be pushing the preload body towards the bottom bracket instead. The preload adjuster in your situation should stay flush against the crankarm. The preload adjuster's inner sleeve (part with the threads) is what should be making contact with bottom bracket.
NiFTY
by NiFTY
I use the above method to determine preload for my setup. Then got a very light headset spacer (fairwheel light carbon style one) and sanded it down to the exact width of the sram screw out spacer, and slightly increased the bore - much better looking and saved about 6 grams.
Kurets
by Kurets
I did the same install using a wave washer and a bunch of .5mm shims. Just put in enough of them that there was no detectable slop once the cranks were torqued to spec.
