eBay carbon saddle?
by addictR1
Well I picked up a carbon saddle from eBay which was shipped from China for $35.
Got it today and tried to mount it only to find the rails are a bit wide. It's really stiff so was wondering if ok & safe to ride with by squeezing it a bit to fit in the clamp and tighten down?
by uraz
Rails will pop in place after you torque the cradle bolts. It will be fine.
by antonioiglesius
There seems to be some variance in the width of the top-down seatpost clamps. Saddle rails should be able to withstand some amount of bending to get them to fit.
by stockae92
Question: the shape of the mounting and rail doesn't seems to match? Does it matter?
by addictR1
ok i just installed it.. figured it's $35 and worth a try. the rails did pop into place.. thank you guys for the advise.
needed a different saddle to use on my indoor trainer CX bike but didn't wanna spend another $199 to get a romin evo pro.
the weight is 155g with padding, which isn't bad. the downside is the rails is pretty short in terms of adjustment (forward and backwards).
