Rotor 3d30, Dura Ace 7800 compatability question
by Nailz
Hi WW,
In an attempt to install a Rotor 3d30 crankset onto my Caad5 (w/ Dura Ace 7800 parts, 68mm bb), I have run into an issue, whereby the chain line has been moved outboard, due to the spindle spacers installed, to accommodate the crank on the frame.
The result has been that I cannot shift into the big ring, even after adjusting limit the limit screw, and pulling more cable through.
Given my FD is a band on, is there anyway around this, without having to purchase more parts? :noidea:
Any help from the collective group wisdom would be greatly appreciated.
