Victoria corsa G+ un-gluing clincher
Allen254
by Allen254
can i just glue this on or is it a throw away?
shimmeD
by shimmeD
80 views (no image with post) - I guess nobody has ever unglued a clincher. :? :roll:
Less is more.
TobinHatesYou
by TobinHatesYou
Assuming the tread is coming off the casing after using the tire on a trainer, but there’s no image. You could definitely glue the tread back in place of you wanted.
Allen254
by Allen254
Sorry you guys I thought he image was showing , but yes the casing is coming off I used some super glue but went ahead and bought a new tire just in case.
eric01
by eric01
Don't risk it. Maybe contact vittoria to see if there's a chance for warranty replacement? Unless you ran it on a trainer...
AX Lightness Vial Evo, Carl Strong Titanium
mattr
by mattr
Allen254 wrote:Sorry you guys I thought he image was showing , but yes the casing is coming off I used some super glue but went ahead and bought a new tire just in case.
Superglue probably not the best thing to use, unless it's the flexible stuff.
scottmmw
by scottmmw
I've had 2 do this to me, with both replaced under warranty. I've kept the 2 as spares and superglued the tread back down, only small part about and inch long. No problems at all!
Marin
by Marin
Had the tread come unstuck on older Open Paves, I used vucanizing fluid to stick it back on. Still riding the tires.
Allen254
by Allen254
Marin wrote:Had the tread come unstuck on older Open Paves, I used vucanizing fluid to stick it back on. Still riding the tires.
yeah I should have had used the vulcanizing fluid instead but I used super glue lol
scottmmw
by scottmmw
Nothing wrong with superglue
Marin
by Marin
scottmmw wrote:Nothing wrong with superglue
If you use the flexible type, yes.
The classic hard type can cut your casing.
