Power2Max 4-hole shimano or 5-hole plus chainrings
r4nd0mv4r14bl3
by r4nd0mv4r14bl3
Thanks for the links. Looks not too bad. To me, Quarq Dfour91 with 9100 rings scores higher for visuals, though. Otherwise, would prefer p2m meter.
Sent from my SM-N9005 using Tapatalk
salesguy
by salesguy
Agreed, plus the quarq is a known quantity with great service. I think this looks pretty good.
morganb
by morganb
Doesn't match up quite as cleanly as the Quarq, but its much less noticeable without a flash because the rings look darker(phone camera issues).
snip001
by snip001
I ended up getting the 5-hole + praxis... I wanted to move back to a 50/34 vs 52/36 (lots of steep climbs here) plus I thought that, while the R9100 + p2m look good, the ultegra looks kinda off because of the dark grayish that the rings are...
reknop
by reknop
I just wonder how waterproof the rubber flap on the NG Eco will be.
https://www.remo-knops.com/cycling/
Boshk
by Boshk
snip001 wrote:
Tue Oct 24, 2017 7:15 pm
How's the praxis rings on your p2m? any dropped chains?
Colnago C60
Philbar72
by Philbar72
reknop wrote:
Fri Oct 27, 2017 1:05 pm
should be fine, the internals are waterproofed as well. but you'd rather have that cap on...
Bordcla
by Bordcla
Advantage of 4-hole Shimano is that you can run any of their chainrings (50-34, 52-36, 53-39 or even bigger), because they all share the 110mm bolt diameter, unlike most competitor's rings.
Plus you can choose top of the line DA rings or more financially accessible Ultegra 6800 or 8000.
P2M has an "how-to" install video on YouTube showing the set up with Ultegra 8000 rings. Very easy to find.
lovemyway
by lovemyway
Quarq looks sweet, too bad they don't make 180mm cranks.
nemeseri
by nemeseri
morganb wrote:
Mon Oct 23, 2017 2:22 am
I know that it was a year ago, but do you have the weight for the cranks + PM and chainrings?
morganb
by morganb
nemeseri wrote:
Tue Mar 13, 2018 4:40 am
I don't, but I will try to get it next time I pull them. I'm likely going to swap them over to a Tarmac, waiting for the disc to come out to decide between that and the rim brake model.
