Shimano EW-RS910 junction box
ms6073
by ms6073
egebhardt wrote:
Sun Nov 12, 2017 4:24 am
I'll pass until they are $5.
So never, right? :roll:
audiojan
by audiojan
tabl10s wrote:
Tue Mar 13, 2018 3:59 pm
audiojan wrote:
Sun Mar 11, 2018 2:46 pm
tabl10s wrote:
Thu Mar 08, 2018 12:32 pm
morganb wrote:
Tue Oct 17, 2017 1:32 am
I'm swapping Di2 from one bike to another and figure this would be a good time to switch to the internal junction box. Will this work with pretty much any internally routed bar? I am pretty set on Zipp SL70 Aero handlebars so would probably run another routing option if those won't work.
It won't work. My LBS mechanic tried after I waited for months to get the darn thing. I have two bikes with the same bar and they aren't completely hollow.
Actually it does work. There's a "plastic bag" in teh drops that needs to be pushed out. I used a coat hanger and a brake cable housing. Took some time, patience and a "few choice words", but finally the bag popped out enough that I could grab it with a needle nose and pull it out. Just did that exact build for a friends bike. Wiring long cable from lower junction to right shifter (wire shrink wrapped to brake housing), wire from right to left shifter, wire from left shiter to 910 junction. Super clean and neat.
Can you show a pic of the results?
Sorry, already delivered the bike
tabl10s
by tabl10s
That's cool. LBS is calling Zipp to inquire.
2016 Orbea Orca OMR:
15.2lbs(6.89kg).
2013 Wilier Zero.7:
13.65lbs(6.19kg).
2016 Rca(build in-process and almost done).
Pinarello F8(incoming).
audiojan
by audiojan
tabl10s wrote:
Thu Mar 15, 2018 11:34 am
The official answer from Zipp is that they are not RS910 compatible as there's no clearance in the drops. Doesn't mean that it can't be done though. :wink:
tabl10s
by tabl10s
audiojan wrote:
Thu Mar 15, 2018 12:41 pm
I don't want to put my mechanic in a position where'd he'd have to purchase a new one if it got damaged. The shop lost my AX seatpost and purchased an Enve because it got lost for my latest build.
15.2lbs(6.89kg).
2013 Wilier Zero.7:
13.65lbs(6.19kg).
turlutu
by turlutu
Change of shop ?
tabl10s
by tabl10s
turlutu wrote:
Thu Mar 15, 2018 1:25 pm
Change of shop ?
Not yet.
15.2lbs(6.89kg).
2013 Wilier Zero.7:
13.65lbs(6.19kg).
tabl10s
by tabl10s
Change of shop ?
Not yet
15.2lbs(6.89kg).
2013 Wilier Zero.7:
13.65lbs(6.19kg).
P90Puma
by P90Puma
So with the SL70 aero and RS910 I was able to make it work but it was not easy.
You have to use some force to get through the extra bagging material used to layup the carbon.
Will post more detailed pictures.
There's some convoluted routing but it's super clean once fully installed.
kode54
by kode54
i don't think i would settle for that. if they lost your AX seatpost...they should replace it with the same. anything else is not acceptable.
tabl10s wrote:
Thu Mar 15, 2018 1:15 pm
- AX Lightness Vial EVO D + DA9150 + Enve SES 3.4 carbon hubs
- Parlee ESX + DA9150 + THM SRM PM + Enve SES 6.7 CK hubs
- Independent Fabrication Ti FLW + DA9100 + Enve 3.4 CK hubs
