It is currently Sat Oct 21, 2017 6:34 am
Post new topic  Reply to topic  [ 39 posts ]  Go to page Previous 1 2 3 Next
PostPosted: Mon Sep 25, 2017 12:55 pm
sure, but still trying to find the origin of the problem without even knowing the user's weight doesn't make much sense to me!
PostPosted: Mon Sep 25, 2017 3:52 pm
I've been riding Enve 3.4 clinchers with DT Swiss 240 Hubset for a while and found that I had to increasingly open the brakes until I could no longer hear brake rub on climbs. I was really surprised, because I hardly had any brake left. I've subsequently heard the same from others locally here.
I don't know if Enve has addressed this issue with the 4.5 but I certainly hope so. The Aeolus is far less prone to brake rub by comparison.
PostPosted: Mon Sep 25, 2017 5:17 pm
damond wrote:
I am surprised no one as yet asked the main (basic) question: how much do you weight and how much power do you output?
1m93 and max 75kg => 165lbs???
Power output doesn’t really matter. I can get Rub without power just by letting the bike go the left and right in a certain angle while riding.
PostPosted: Mon Sep 25, 2017 5:40 pm
Zipp has study on brake rubbing and stiffness.
Stiffer wheel has more moving at brakepads.
There is article on internet
http://kavitec.blogspot.com/
click this! http://www.youtube.com/watch?v=0m8maAO-m-w
PostPosted: Mon Sep 25, 2017 6:58 pm
http://www.slowtwitch.com/Tech/Debunkin ... _3449.html
PostPosted: Mon Sep 25, 2017 8:17 pm
StradaJon wrote:
What Ergott says - the CX Ray is not strong enough. We use a thicker gauge spoke now on all ENVE road builds, especially tubeless ready rims.
Yup. My first Enve wheels were stock Enve builds with 240 hubs and CX-Ray spokes.
I have a few new sets with White T11 hubs and DT Race db spokes - much better.
PostPosted: Tue Sep 26, 2017 6:59 am
kavitator wrote:
http://www.slowtwitch.com/Tech/Debunking_Wheel_Stiffness_3449.html
Great article. Thanks!
PostPosted: Tue Sep 26, 2017 1:49 pm
Good stuff. Thanks for sharing.
I’ve had a pair of enve 4.5s for the past 2 seasons and never had an issue with brake rub that I’ve noticed. Stock build with dtswiss 240s.
PostPosted: Wed Sep 27, 2017 9:26 am
Very nice and interesting article on wheel stifness.
Great!!!
PostPosted: Thu Sep 28, 2017 9:41 pm
if there is side-to-side play in the rear wheel...does that mean that the bearing races are shot? in one of my Enve carbon hubs, i have similar side to side play. skewers are tight. when i pinch my fingers where the hub is and the outer caps, i can feel the axle move when i move the wheel back and forth.
- AX Lightness Vial EVO D + DA9070 + Enve SES 3.4 carbon hubs
- Parlee ESX + DA9070 + THM SRM PM + Enve SES 6.7 CK hubs
- Independent Fabrication Ti FLW + Campy SR11 + Enve 3.4 CK hubs
PostPosted: Fri Sep 29, 2017 12:45 pm
ENVE 7.8 with ENVE hubs and I get brake and chainstay rub. Switching to a 23mm tire took care of the chainstay rub but brake rub still occurs. DS tension confirmed at an avg of 110. My personal opinion reflects what I've read here from the wheel builders that have chimed in on this thread; bracing angle and spoke flex.
Question for ergott or stradajon: Would the CX-Sprint be strong enough or do I need to switch to a non aero spoke for the DS?
PostPosted: Fri Sep 29, 2017 2:08 pm
CX-Sprint and DT Aero Comp are equivalent to Sapim Race and DT Competitions respectively. They should help. Honestly, a different hub would make a bigger difference. Nothing beats the Wheels Mfg hub for this. Better bracing angles and also better bearing placement so there's less unsupported axle. It's like going from a square taper crank/BB to outboard BB setup.
www.ergottwheels.com
PostPosted: Fri Sep 29, 2017 2:24 pm
I agree but with the carbon hub investment already made, I would prefer to make this setup work and keep the Alchemy or Carbon-Ti X-Hub Road SP option for the next build. Thank you for your valued input, I will likely go with CX-Sprints for the DS on the 7.8 rear.
PostPosted: Fri Sep 29, 2017 2:29 pm
Since the spacing is narrower on the Enve hub and low tension on the left isn't an issue, I'd recommend Sprints on both sides of rear wheel. Only a 25g bump in weight. Should definitely help current situation.
PostPosted: Fri Sep 29, 2017 2:30 pm
Any thoughts on berd polymer spokes? http://www.berdspokes.com/
There are no new unread posts for this topic. Non-enve pads on enve wheels
AttacknowAttackoften
27
2281
Tue Oct 10, 2017 11:25 pm
RyanH View the latest post
There are no new unread posts for this topic. Enve 3.4 V2 tubular
solarider
Fri Jun 16, 2017 7:26 pm
solarider View the latest post
There are no new unread posts for this topic. Combining Enve models
gurk700
12
1255
Thu Jan 26, 2017 10:17 pm
gurk700 View the latest post
There are no new unread posts for this topic. Enve 3.4 SES and Zero Gravity Brakes
markcp
Tue May 23, 2017 4:15 pm
Beaver View the latest post
There are no new unread posts for this topic. Enve shipping proxy - USA to the UK
Broady
Tue Jan 24, 2017 12:51 am
Broady View the latest post
Users browsing this forum: Baidu [Spider], BeeSeeBee, Gearjunkie, hypercycler, Kayo, rajMAN, stormur and 38 guests
