It is currently Sat Oct 21, 2017 10:48 pm
Post new topic  Reply to topic  [ 39 posts ]  Go to page 1 2 3 Next
PostPosted: Wed Sep 20, 2017 4:11 pm
Yesterday was the big day that i finally got my new bike:
- Frameset BMC SLR01 2018 (rim brake version)
- Groupset Dura Ace DI2 9150 (direct mount brakes)
- Wheels ENVE SES 4.5 with ENVE hub (25mm vittoria tyres on it)
First ride and i heard brake rub from my rear wheel (i think it is brake rub because it sounds like the breaking noise).
Also when it is happening i'm checking my front wheel and in how much it is possible i don't see the front wheel touching the brakes so i must be the rear wheel.
When do i get it:
- When i stand on my pedals and push more wattage
- Climbing on the pedals => always
- Just standing on my pedals and move my bike from left to right (NO pushing on the pedals)
I have open the direct mount brakes more so that there would be more clearance but the brake rub stays.
The next thing i gonna try is to ride with a quick releas from another wheel that i have to see if that would help.
Would i have a faulty hub/wheel?
PostPosted: Wed Sep 20, 2017 4:13 pm
probably flex...but it sounds like clearance issues. maybe inside of your chain stays? tire rubbing marks anywhere?
- AX Lightness Vial EVO D + DA9070 + Enve SES 3.4 carbon hubs
- Parlee ESX + DA9070 + THM SRM PM + Enve SES 6.7 CK hubs
- Independent Fabrication Ti FLW + Campy SR11 + Enve 3.4 CK hubs
PostPosted: Wed Sep 20, 2017 4:21 pm
I have the same problem with my enve ses 4.5 . I have chris king hubs and my weight is 79kg.
PostPosted: Wed Sep 20, 2017 4:33 pm
No rubbing marks.
Also space enough everywhere in the rear triangle. The new BMC is made for tires off 28mm.
PostPosted: Wed Sep 20, 2017 4:34 pm
Did you never found a solution? What does the shop says where you have bought them?
PostPosted: Wed Sep 20, 2017 5:00 pm
Is there any movement in the hub? Try to move the rear wheel from side to side with the quick release closed.
Do you have another wheelset? If it doesn't happen on the other wheelset then you know for sure it's your Enve wheel.
PostPosted: Wed Sep 20, 2017 6:19 pm
I can move the wheel from side to side with the QR closed.
PostPosted: Wed Sep 20, 2017 6:29 pm
Is there a preload adjustment on Enve hubs?
I know when I had 6.7s with CK hubs i had to adjust.
I'm using extralite on my 4.5 and 2.2... I can still do it.. but it's super rare that I get brake rub now.
PostPosted: Wed Sep 20, 2017 6:32 pm
sounds like too much play. but with the Enve hubs...they are carbon with DT Swiss internals...so shouldn't really have play in it. bearings could be shot if there's play in the hub. i was going to suggest checking the spoke tension..
PostPosted: Wed Sep 20, 2017 6:45 pm
The enve hub has ceramicspeed bearings. Then you exept a very stiff hub and no brake rub...
PostPosted: Thu Sep 21, 2017 1:26 pm
Enve hub doesn't improve the flange spacing of a DT hub which has been proven to have lack of lateral stiffness. When I wanted to solve the problem of brake rub for someone (different hub) I rebuilt the Enve 4.5s to Wheels Mfg hubs and used DT Aerocomps for the right rear. It stiffened up the rear wheel and he no longer has any rubbing issues.
www.ergottwheels.com
PostPosted: Sun Sep 24, 2017 9:33 pm
I'd say open the rear brake completely and go out for a ride and carefully (you only have one brake) put the power down where it is safe to do so. If you get rub still, you can rule out brake rub.
Rubbing sounds can come from a lot of places. Shoe on the crank for example.
PostPosted: Mon Sep 25, 2017 11:52 am
What Ergott says - the CX Ray is not strong enough. We use a thicker gauge spoke now on all ENVE road builds, especially tubeless ready rims.
Strada Hand Built Wheels
http://www.stradawheels.co.uk
PostPosted: Mon Sep 25, 2017 12:28 pm
Online
I am surprised no one as yet asked the main (basic) question: how much do you weight and how much power do you output?
PostPosted: Mon Sep 25, 2017 12:49 pm
Those are important points in general, but riding style/technique plays a big role in brake rub. You can be 165lbs and rocking the bike out of the saddle on a hill and see the problem. How much you rock the bike is more of an issue than ultimate power output.
There are no new unread posts for this topic. Non-enve pads on enve wheels
AttacknowAttackoften
27
2283
Tue Oct 10, 2017 11:25 pm
RyanH View the latest post
There are no new unread posts for this topic. Enve 3.4 V2 tubular
solarider
Fri Jun 16, 2017 7:26 pm
solarider View the latest post
There are no new unread posts for this topic. Combining Enve models
gurk700
12
1256
Thu Jan 26, 2017 10:17 pm
gurk700 View the latest post
There are no new unread posts for this topic. Enve 3.4 SES and Zero Gravity Brakes
markcp
Tue May 23, 2017 4:15 pm
Beaver View the latest post
There are no new unread posts for this topic. Enve shipping proxy - USA to the UK
Broady
Tue Jan 24, 2017 12:51 am
Broady View the latest post
Users browsing this forum: Baidu [Spider], salesguy, uraz and 44 guests
