Lightest 30mm crank (bb30 = ok) with removable spider
mythical
by mythical
Couldn't resist...
That's the total weight including 3D printed titanium DS + NDS arms and alu axle, 130BCD spider with 36T inner ring and clamping mechanism but without BB bearings, chainring bolts or a big ring.
The production version will be gain about 10-15 grams or so, and the wait is now for new printed arms with a slight redesign. The final issue remaining is some finetuning of the production process before releasing them into the wild. Separate spiders will also be available.
“I always find it amazing that a material can actually sell a product when it’s really the engineering that creates and dictates how well that material will behave or perform.” — Chuck Teixeira
RideWert.com
Wert Cycling on Facebook
thumper88
by thumper88
Hard to beat the grams to dollars of an s-works. A really good used one -- no axle wear -- is a huge bargain in the world of light cranks and will last forever. I favor the scratched up ones. Quick sanding and a bit of clear coat and its nearly good as new for a pittance,
AZR3
by AZR3
mythical wrote:Couldn't resist...
I was waiting for someone to come out with a light weight 3D printed Ti crankset, just seems like a great use for 3D printing. You can build up some internal structure to make it light and stiff, I imagine price will be $$$$$ though
thumper88
by thumper88
alcatraz wrote:A user did a comparison and here are the findings:
2010 or 2011 Specialized crank - 175mm / 52/36 - comes with alloy spider
- 556g for complete crankset
- 149g for Left Arm
- 237g for Right Arm + Alu Spider
- 34g for 36t chainring
- 116g for 52t chainring
2011 S-works crank - 172.5 50/34 - comes with carbon spider
- 520g for complete crankset
- 152g for Left Arm
- 223g for Right Arm w/Carbon Spider
- 30g for 34t chainring
- 99g for 'S-works' 50t chainring
It appears the difference is in the spider. None of these two weigh over 400gr though. I suspect newer models have been beefed up compared to the old ones. Good for people like me though that like to save a buck and buy older stuff.
/a
I did same comparison between a pro-level one with alloy spider and an s-works one and then removed the spiders and weighed the bits separately. I can't remember the difference in spider weight, maybe 20-30 grams, but... that WAS the sole difference. They weren't identical otherwise but so close that it was manufacturing margins, logo etc... like, @12 grams.
alcatraz
by alcatraz
What about crank lengths? Maybe thats where the difference was.
I'm looking solely for 170mm cranks.
/a
prendrefeu
by prendrefeu
Any chance you'll have this for BBRight, 172.5, 110BCD ?
mythical
by mythical
All of the above, except it won't be compatible with Trek's annoying BB90 drop-in bearing shell.
BB standards it does support: BSA, ITA, BB30, BB30A, BB386Evo, BBright and BB86 (did I forget any?)
RideWert.com
romalor
by romalor
Threadfit 47 ;)
AZR3
by AZR3
So what’s the ETA and price on this crazy crank?
eric01
by eric01
Isn't T47 the same as BB30 from a crank compatibility point of view? 30mm spindle, long enough to clear 68mm shell. yes obviously not the same from a frame point of view (threaded).
AX Lightness Vial Evo, Carl Strong Titanium
nickf
by nickf
My lightning crank
Non driveside arm-153g
Driveside w/ 110bcd spider- 226
Built with extralite MC rings- 492
30mm spindle w/ a wide spindle. Will fit a standard 68mm bsa shell with their bb.
alcatraz
by alcatraz
nickf wrote:My lightning crank
Really cool. Can a wide spindle be mounted or does it have to come from the factory?
/a
dlud
by dlud
My Cannondale SISL2 comes in at 496g:
50/34 Spidering: 158g
DS crank/spindle/bolts/lock ring: 213g
NDS crank: 125g
alistaird
by alistaird
My Campy Over Torque:
ImageDSC_0048 by A&D D, on Flickr
A
prendrefeu
by prendrefeu
alistaird wrote:My Campy Over Torque:
Nice crank. It does not have a removable spider.
alcatraz wrote:Lightest 30mm crank (bb30 = ok) with removable spider
alcatraz wrote:This time I'd like a removable spider
:wink:
