It is currently Tue Jan 23, 2018 9:23 am
Post new topic  Reply to topic  [ 3 posts ]
PostPosted: Wed Sep 13, 2017 9:24 pm
Usually before some races I prefer to warm up on trainer, works better for me. But I have avoided using my veloflex tubulars on it and at times can be a pain when shorter on time and all.. How much hard would warm ups on trainer cause the texture from the tire?
PostPosted: Fri Sep 15, 2017 8:08 am
Don't use tubulars with glued on treads with wheel-on trainers if you can avoid it. The glue can melt and get squeezed out from between the casing and tread.
If you do, make sure you don't squeeze the tire too hard with the roller and don't go particularly hard.
PostPosted: Sat Sep 16, 2017 10:38 am
I'd be weary of using tubies on a trainer even for short warmups, specially tubies as soft as the Veloflexes. Turbos chew up tires fast, the softer the tire the disproportionately faster it'll destroy it. To say nothing of the heating of the glue that Tobin described...
I'd go with rollers or a specific turbo wheel....
There are no new unread posts for this topic. Attachment(s) Trainer Voids Canyon Warranty
[ Go to page: 1 2 3 4 ]
asv
45
5880
Tue Feb 21, 2017 6:49 am
alastairb View the latest post
There are no new unread posts for this topic. can i make a 54cm frameset fit me for a trainer setup (normally on a 56)?
motorthings
10
877
Thu Nov 02, 2017 4:35 pm
motorthings View the latest post
There are no new unread posts for this topic. Wahoo KICKR trainer issues. Read if you use Campagnolo!!
dgasmd
20
1379
Sun Oct 29, 2017 3:08 pm
basurper View the latest post
There are no new unread posts for this topic. Winter tires recommendation
CallumRD1
Mon Oct 09, 2017 4:37 pm
CallumRD1 View the latest post
There are no new unread posts for this topic. Best tires for wet, rough roads
nemeseri
38
2940
Tue Aug 08, 2017 7:06 pm
Bigger Gear View the latest post
Users browsing this forum: alistaird, Baidu [Spider], Conza, jlok, MattN, vladi78 and 29 guests
