It is currently Tue Jan 23, 2018 9:22 am
Post new topic  Reply to topic  [ 11 posts ]
PostPosted: Wed Sep 13, 2017 2:26 pm
I have 2 questions. On my road bike with eTap I have been experiencing some interesting conditions. Prior to a chain change the bike would occasionally shift (i think) into a 1/2 position and make some noise like the derailleur was off position. within a couple of seconds it could go back into position. I just changed the chain for the first time from the original 1190 (1500 miles, started to show wear) to a PC1170. now I am getting the 1/2 position all the time, I have tried to see if the derailleur moves but cannot see anything, I also cannot recreate the situation on the stand.
1) has anyone else see this condition
2) has anyone else run PC 1170 chains with a full eTap system
Thanks
PostPosted: Wed Sep 13, 2017 3:02 pm
Is the quick connect link facing the proper direction?
PostPosted: Wed Sep 13, 2017 3:08 pm
yes, thanks. 1st thing LBS checked. keeping me honest
PostPosted: Wed Sep 13, 2017 3:16 pm
Thanks
The front derailleur has a feature, if you visually check, that after the shift occurs it realigns itself. It hangs like you said about 1/2 way before it moves all the way to the resting position.
I noticed this but it has never caused me any trouble. The only trouble I had was chain drop from small chainring to the big. This happened due to lack of "excellent" adjustment.
Other than that and the batteries tabs breaking off I love it.
PostPosted: Wed Sep 13, 2017 3:19 pm
definitely rear derailleur based sound
PostPosted: Wed Sep 13, 2017 3:25 pm
Oh I thought it was the front. My bad. You might have a defective unit.
PostPosted: Wed Sep 13, 2017 3:33 pm
not sure because the unit has been working for 3 months.
PostPosted: Wed Sep 13, 2017 4:03 pm
If your gears are indexed correctly and the drivetrain is lubricated to run smoothly I don't really see what could cause anything like this. The derailleur moves a certain amount when you shift, now you say you can't replicate when on the workstand so if you want to adjust under load then find a quiet piece of road and give it a few adjustment clicks up on the STI whilst riding and/or try the same with a few clicks down.
When I first read this you were referring to the FD, as that purposefully 'overshifts' when going outbound and then relaxes back into position to help with the shift.
PostPosted: Wed Sep 13, 2017 9:01 pm
The rear derailleur also automatically shifts when it detects a failed shift. I suspect this is what it's doing, since a half-shift condition is being replicated. Micro-adjust your derailleur cage alignment so the chain makes no noise in the 5th and 6th cogs while pedaling. Then check to see if it shifts all the way through the cassette.
Also check to see if your derailleur hanger is bent.
PostPosted: Wed Sep 13, 2017 10:01 pm
I will try that
PostPosted: Wed Sep 13, 2017 10:08 pm
hanger is straight, and 5/6 sounded quiet but i made a 2X micro adjustment one way and took it for a quick ride. it was quiet. I will take a ride tomorrow or Friday. you may have had the golden ticket. i will let you know thanks
There are no new unread posts for this topic. Sram Etap compatability
Allen254
7
695
Sun Oct 29, 2017 9:33 am
Allen254 View the latest post
There are no new unread posts for this topic. eTap cross chain issues?
possibleweenie
Sat Jul 08, 2017 10:13 pm
possibleweenie View the latest post
There are no new unread posts for this topic. Sram etap FD chain drops
felshampo
Wed May 10, 2017 6:19 pm
felshampo View the latest post
There are no new unread posts for this topic. SRAM etap chain length...
addicted
Thu Apr 27, 2017 2:01 pm
ergott View the latest post
There are no new unread posts for this topic. Chain Advice for Shimano/Sram eTap Configuration
mrtkcmz
Tue Jul 18, 2017 6:24 am
alcatraz View the latest post
Users browsing this forum: alistaird, Baidu [Spider], Bing [Bot], jlok, vladi78 and 24 guests
