It is currently Sat Jan 20, 2018 4:05 pm
Post new topic  Reply to topic  [ 15 posts ]
PostPosted: Tue Sep 12, 2017 9:44 pm
I'm thinking about building an aero road bike next year, and really like the TriRig aero brakes.
Plus, they're reasonably light :) !!
What i'm not shure about is braking power and reliability for road race use ( criteriums, downhill, emergency braking, etc...).levers..
And also pulling ratio with SRam22 levers...
Anyone has an extensive experience with these brakes on a road build ?
Louis :)
PostPosted: Tue Sep 12, 2017 10:07 pm
I'm not very qualified to answer; far from extensive experience, not much to compare with, not the latest brakes etc, I'm only 120 lbs, don't ride big mountains, used with Campag levers.
They have made incremental improvements over the ones I have, but I don't know if they've added toe adjustment. The ones I have are no way near as powerful as EE. I had been riding it on the front paired with EE under the chain stays. Swapping them around might be a better move, but I'm yet to ride my bike like this. I've seen pics of WT bikes esp on rear.
Less is more.
PostPosted: Tue Sep 12, 2017 11:18 pm
Louis :)
They work fine on road bikes generall. I ran one on the front of an S5 for a couple of years with no issues. Stopping was very good. Not dura-ace good, but very good.
There was no need to run one in the back as the rear caliper is hidden from wind on that frame.
I was using shimano, cant speak to the function with SRAM.
PostPosted: Tue Sep 12, 2017 11:49 pm
Yeah, I'm inclined to disagree. I used one on the front of my AR within the last year (using etap) and the stopping power was not even on par with Aerolink. I guess it's fine if you don't need to stop often, but definitely don't expect to slow down in a hurry or have much brake feel. It is a clever design though.
Current:
T2
Retired:
PostPosted: Wed Sep 13, 2017 12:00 am
I ran the original Omega for a few months on on my TT bike and found the braking to be lackluster (me at 140lbs, brake setups were: Koolstop Salmon + aluminum rims, Zipp cork + Firecrests, Zipp Platinum Pro + Firecrests) . If I was just racing I would have kept them, but it was the training in traffic, down hills, etc. that made me ditch them. I'd never consider them on my road bike. Can't say the company or the product quality really impressed me that much :noidea:
PostPosted: Wed Sep 13, 2017 1:16 am
I'm over 100KG and they work great on my Mosaic RT-1 with SR EPS and Campy Red Pads on BORA ultra's. As good as Campy or EE. It's all in the set-up - they can be toed in.
PostPosted: Wed Sep 13, 2017 3:04 am
You're outside your mind to say they're comparable to EE or Campy. Perhaps if you toe in the Tririg and use wet cork pads on the others.
For those saying tri rig stops great, do you have hills you ride down? Much traffic? I suppose they'd be fine if I was just riding on flat, rural roads
Current:
T2
Retired:
PostPosted: Wed Sep 13, 2017 6:41 am
The old version was OK, not great. Would not recommend them.
New version is good, commute on them 20 miles each way through London rain or shine. they are on par with my EE brakes on other bike. What I mean by that is that I don't worry one bit with them on the bike while commuting. and I am quite heavy with backpack etc when travelling to and from work.
PostPosted: Wed Sep 13, 2017 7:43 am
Agree with others, old Omega was not that impressive.
Omega X seems to be built much more solid, better braking power and so on. No problem with flat racing on these, including races on closed circuits with some sharp turns, but to compare them with DuraAce would be a stretch.
PostPosted: Wed Sep 13, 2017 11:07 am
Administrator
Could be wrong but I believe BmanX runs a set on his English with zero problems. I run them on my tt bike. When I need to stop the bike stops,
RESIDENT GRUMPY OLD MAN.
PostPosted: Wed Sep 13, 2017 2:13 pm
No I'm not outside my mind.
9 times out of ten when Brakes don't work that great it's due to installation issues.
I did a swap between EE's and OmegaX on the same bike with the same Brake Pads (literally the same) on the same wheels. There was no appreciable difference between the two.
And yes I go down hills and I ride in lots of traffic - they provide more than enough braking force when needed, and I've been riding long enough to know what Cork pads in the rain on some of the first Carbon wheels (circa 2005) felt like.
PostPosted: Wed Sep 13, 2017 4:30 pm
I responded to your question in my intro thread, but I'll respond here as well in case somebody searches for this in the future.
I have front and rear TriRig Omega X brakes using SRAM22 road brifters / levers on a 2015 Cervelo S5. After a year and a couple thousand miles, I find that the setup works great for me; I haven't ever wished for a different braking setup. My previous brakes were Shimano Ultegra 6800.
Here's a reference link to my build thread: http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=140601
damen
PostPosted: Wed Sep 13, 2017 6:07 pm
Been running latest and previous generation of Omega brakes on multiple bikes with zero issues. Braking is superb and had never wished or needed more breaking power or modulation. They work very well.
PostPosted: Wed Sep 13, 2017 7:31 pm
They've made the arms progressively stiffer which is why current version is better than original. Also the cam shape moves the pads rapidly inwards at first then more slowly. The independent adjustment of pad distance is really nice. The aero cover is fragile so treat it carefully. They're good brakes but I have not done a direct comparison with a conventional caliper.
PostPosted: Fri Sep 15, 2017 4:29 pm
I will reiterate, it worked fine for me just running a front one on an S5 and a 9000 caliper on the rear. Stopping was good, though I will say I used pretty good pads and running carbon wheels with rim brakes stopping is never really going to be ideal.
I probably put 12,000 miles on that setup, including 30 races, road nats etc. and you can disagree all your want, my views have basis in experience.
The other caveat is there are no mountains or technical descents of any kind where I ride day in and day out, just endless rollers in the 1-4 minute, 3-6 percent range.
There are no new unread posts for this topic. THM Fibula brakes-setup help required
retired
9
1142
Tue Aug 22, 2017 11:59 pm
retired View the latest post
There are no new unread posts for this topic. Road Disc Brakes- Rotor Choice
[ Go to page: 1 2 3 4 5 ]
mdeth1313
73
7206
Fri Jan 12, 2018 12:57 am
simoncx View the latest post
There are no new unread posts for this topic. Nice carbon bar and stem setup?
PLuKE
11
1484
Wed Aug 23, 2017 6:09 pm
PLuKE View the latest post
There are no new unread posts for this topic. Changing setup, Aeronova/SL70
PLuKE
Tue Mar 21, 2017 9:30 pm
There are no new unread posts for this topic. can i make a 54cm frameset fit me for a trainer setup (normally on a 56)?
motorthings
10
861
Thu Nov 02, 2017 4:35 pm
motorthings View the latest post
Users browsing this forum: Bing [Bot], cwdzoot, dukeduke1, duzza, fitty4, Zakalwe and 53 guests
cron
